01-23-2012, 23:27 | #1 (permalink) |
Registered User Join Date: Apr 2010 Location: brazil
Member: 1289396 Status: Offline Thanks Meter: 12 | Error Flash gx200 I have a problem to flash on the GX200 model Z3X, it is restarting, I tried reset and format, time to flash this error ... 100% battery |
11-15-2013, 18:47 | #6 (permalink) |
Major Poster Join Date: Jan 2008
Member: 674434 Status: Offline Thanks Meter: 3 | Gemalto Card Tests Ok! Scanning Download Agents... Port enumeration Failed! Selected model is:Motorola WX160 Scanning Download Agents... Updating Flash Configuration... Welcome to MTKModule v2.1.0.3 Card S/N:0002-DFE7 Card ver.2.2 BROM.DLL Version :BROM_DLL_v3.1044.00 From 2010/11/05 12:42:46 META.DLL Version :META_DLL_v6.1044.00 From 2012/03/26 12:52:38 Detecting Loaders ... Download Agents Found :0 Ready. Selected model is:Motorola WX160 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... Selected model is:Motorola WX160 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:Motorola WX160 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... Selected model is:LG GX200 Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [WRITE_MODE] Formatting after download DISABLED Reconnect battery and press power button now! Download Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Done! Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! ReadBack Failed:? Error: S_COM_PORT_OPEN_FAIL(1011) BOOT Analisys failed... Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... META_ConnectWithTarget(): ERROR: Failed to open com port or setup com port Selected model is:LG GX200 Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... Connected in META Mode. BaseBand Chip version : MT6235, E04 DSP Firmware ver. : 2000.00.00 Software version : GX200-00-V10g-AME-XX-MAY-11-2010 Hardware version : Melody version : Melody V0.0 NVM Reset OK. Operation Done! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
