Old 11-29-2011, 16:13   #1 (permalink)
EDV11's Avatar
Member: 9489
Thanks Meter: 35
Error flashing LG A110
Here is the error I get
LG 2-3G Tool v2.4 build 00A2
supported models: 479
Selected model: A110
Selected port: COM49
Selected speed: 115200
Connect phone and press Power ON!
Connect ok!
Send preloader ok!
Send main loader Ok!
Change BaudRate done!
FlashId: 88280020, flash size: 4Mb
IMEI: 354615-04-244496-5
NCK Code: 0709 8742 6882 1281
Start write binary file: BIN_LGA110AT-00-V10d-262-XXX-NOV-15-2010+0.bin
Start erase: 0x00800000-0x00BF0000
len:0
out:1000
false
Start erase: 0x00800000-0x00BF0000 ERROR!
Elapsed: 12 secs. --> (v2.4 build 00A2)
Phone is fully working. I use LG UART cable
Old 11-29-2011, 16:22   #2 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
try use different vesion, i check.
Old 11-29-2011, 16:39   #3 (permalink)
EDV11's Avatar
Member: 9489
Thanks Meter: 35
I also tried a different version, but with the same result
Old 11-29-2011, 16:43   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
I tomorrow get this phone end try flash and post result.
Old 11-29-2011, 17:11   #5 (permalink)
EDV11's Avatar
Member: 9489
Thanks Meter: 35
I'll be waiting for your update
Old 12-05-2011, 18:19   #6 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
I check in my phone with same flash id all ok, please try few times with different cable, phone need connect without battery.
Old 12-05-2011, 18:34   #7 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Please select in model list A170 and try flash, wait result
Old 12-07-2011, 12:09   #8 (permalink)
EDV11's Avatar
Member: 9489
Thanks Meter: 35
Thanks, selecting A170 works fine
Selected model: A170
Connect ok!
Send preloader ok!
IMEI: 354615-04-239680-1
NCK Code: 2768 3563 0915 9906
Start erase: 0x00800000-0x00BF0000 OK!
Start write 0x00800000-0x00BF0000 OK!
Elapsed: 518 secs. --> (v2.4 build 00A2)
Phone disconnected
The Following User Says Thank You to EDV11 For This Useful Post:
Old 12-07-2011, 16:29   #9 (permalink)
EDV11's Avatar
Member: 9489
Thanks Meter: 35
Ok, so I have flashed many of these phones till now with no problem. There is only one that I had problems with, it was always stuck on erasing, so I left it to the end.
After trying different set ups, I rolled back and selected A110 again, and it flashed perfectly fine. Here is the log for reference
Selected speed: 921600
Connect ok!
Send preloader ok!
FlashId: 260600EC, flash size: 4Mb
IMEI: 354615-04-237875-9
NCK Code: 5862 2247 2333 1621
Start write binary file: ROM_LGA110AT-00-V10a-208-XXX-OCT-13-2010+0.bin
Elapsed: 166 secs. --> (v2.4 build 00A2)
Old 12-07-2011, 16:36   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
In last phone FlashId: 260600EC, flash size: 4Mb, in previous FlashId: 88280020, flash size: 4Mb.
if 260600EC select a110
if 88280020 select a170
In next version fixed
The Following User Says Thank You to andrew_tm For This Useful Post:
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.21625 seconds with 9 queries
