10-18-2017, 17:49 | #1 (permalink) |
Junior Member Join Date: Nov 2010 Location: Shushtar.ir Age: 40
Member: 1449120 Status: Offline Thanks Meter: 1 | error repair DRK sm-g925i .. please help me ! flash in 4 file G925IDVU3FQH3_G925IKSA3FQH1_Farsi Arabic Android 7.0_4File Firmware Operation: Repair DRK Selected model: SM-G925I Software version: 29.5 REPAIR INSTRUCTIONS: Reset EFS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Operation: Repair DRK Selected model: SM-G925I Software version: 29.5 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925IDVS3EPC1 Platform: exynos7420 Boot serial: 1215fc1472b30804 Product board: zerolte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.29.5 im writed s bot from 6.0.0 ver and downgread modem to 5 but not solved please help me ! |
10-19-2017, 23:05 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
