08-10-2016, 10:21 | #1 (permalink) |
Banned Join Date: Aug 2005
Member: 172448 Status: Offline Thanks Meter: 5 | Error in writing cert G920F (New Baseband Security) software cant repair or write cert to phone log : Code: Operation: Write CERT Selected model: SM-G920F Software version: 26.3.1 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: PDA version: G920FXXU4DPG8 CSC version: G920FPHN4DPG1 CSC country code: The Netherlands CSC sales code: PHN HW version: Phone S/N: RF8G90FHJ2T Modem board: RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.3.1 and in this new version modem baseband structure added with secondary bootloader an protected and even after downgrade baseband(Cp) become unknown Whats a solution supporter ? |
The Following User Says Thank You to Masoud.ebi For This Useful Post: |
08-10-2016, 11:06 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | iam also waiting i have G920FXXS4DPGA 6.0.1 still waiting for solution to write cert...people try to help with untested solution..but not working... |
08-10-2016, 20:41 | #6 (permalink) |
Member: 172448 Status: Offline Thanks Meter: 5 | G920F partition list Code: 1|shell@zeroflte:/ $ ls -al dev/block/platform/15570000.ufs/by-name lrwxrwxrwx root root 2015-04-13 15:12 BOOT -> /dev/block/sda5 lrwxrwxrwx root root 2015-04-13 15:12 BOTA0 -> /dev/block/sda1 lrwxrwxrwx root root 2015-04-13 15:12 BOTA1 -> /dev/block/sda2 lrwxrwxrwx root root 2015-04-13 15:12 CACHE -> /dev/block/sda16 lrwxrwxrwx root root 2015-04-13 15:12 DNT -> /dev/block/sda10 lrwxrwxrwx root root 2015-04-13 15:12 EFS -> /dev/block/sda3 lrwxrwxrwx root root 2015-04-13 15:12 HIDDEN -> /dev/block/sda17 lrwxrwxrwx root root 2015-04-13 15:12 OTA -> /dev/block/sda7 lrwxrwxrwx root root 2015-04-13 15:12 PARAM -> /dev/block/sda4 lrwxrwxrwx root root 2015-04-13 15:12 PERSDATA -> /dev/block/sda13 lrwxrwxrwx root root 2015-04-13 15:12 PERSISTENT -> /dev/block/sda11 lrwxrwxrwx root root 2015-04-13 15:12 RADIO -> /dev/block/sda8 lrwxrwxrwx root root 2015-04-13 15:12 RECOVERY -> /dev/block/sda6 lrwxrwxrwx root root 2015-04-13 15:12 SBFS -> /dev/block/sda14 lrwxrwxrwx root root 2015-04-13 15:12 STEADY -> /dev/block/sda12 lrwxrwxrwx root root 2015-04-13 15:12 SYSTEM -> /dev/block/sda15 lrwxrwxrwx root root 2015-04-13 15:12 TOMBSTONES -> /dev/block/sda9 lrwxrwxrwx root root 2015-04-13 15:12 USERDATA -> /dev/block/sda18 whitch partition need to flash for downgrading specially sboot.bin cm.bin and param.bin ??? |
08-10-2016, 22:13 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | If knox is tripped do this to write cert on new security. Root phone with CF AUTO ROOT. Then use new z3x 26.3 exynos unlock solution to unlock phone. This also resets the MSL. Then write cert with z3x 22.6 CLICK HERE TO DOWNLOAD Z3X 22.6 |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
08-10-2016, 23:45 | #10 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G920T Software version: 22.6 Checking certificate file... OK KEY ID: 0346 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 6.0.1 Product code: Phone version: G920TUVU4EPF1 PDA version: G920TUVU4EPF1 CSC version: G920TTMB4EPF1 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization AT RIL... error Done with Samsung Tool PRO v.22.6 |
08-11-2016, 06:16 | #13 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
08-11-2016, 07:56 | #14 (permalink) | ||
Member: 172448 Status: Offline Thanks Meter: 5 | Quote:
your solution not work , phone successfully Unlock with 26.3 but cant write cert via 22.6 . log Quote:
