FAQ - LG Phones. Some users have problem when they try to unlock phone or flash phone with Sgold3 Some of problem like : Connecting to KP501 in UART Mode (COM6 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:UNK:D5) prebooting... Preloader answer failed... BOOT Failed Disconnected. Or PMB8877 Module 1.1 started. SW: Ver 2.2.2.137 Connecting to KP501 in UART Mode (COM6 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:UNK:D5) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Ok now how to jump All this problems (Thx to Team to make usb mode) 1- Run driver And install it C:\Program Files\Z3X\LG\LGI_SG3\drivers 2-Now plug phone Pwr Off Pc will ask Drivers Phone Must be Pwr Off, do like picture And Complet Install http://img246.imageshack.us/img246/5125/27827591.jpg 3-Disconnect Phone Ok now we are Ready Open Sgold3 any Version 4-Tick Usb 5-Press connect 6-Now Plug phone Pwr off http://img246.imageshack.us/img246/397/72632085.jpg You can use usb mode also for flash Same Steps (Very Very Fast ) About cable who want use Usb mode Cable is Kg800 usb Enjoy With Z3x Box ,Team & Freinds ;) B,r Souhail_gsm |
Faq: How input modem nck code into modem?? these days i always seen many users of z3x asking how insert nck code for modem into modem using datacard tool i will give you 3 options 1) Goto At Terminal in software and send in modem port this command : AT^CARDLOCK="code" 2) download http://rapidshare.com/files/29502132..._INPUTTER_.exe connect modem and insert nck... JOB DONE!! 3) insert wrong sim and load dashboard... should ask for nck code.. so insert nck code from datacard tool. FAQ 2... Q..what use is flashcode?? A.. when flashing modem.. depending on modem firmware it will ask for flash code to proceed.. this is use of having flashcode. huawei modem firmware can be found here http://www.3gdrivers.x10hosting.com/ |
v13 a lg u880 when i downgrade v10b then 3% flash now in this time power batton press restart problem please help urgent |
sir blang how to use this file in z3x lg software, downloaded from z3z support. DZ_GT540AT-00-V10b-206-XX-MAY-12-2010.dz what sort of software use to extract this file for flashing with z3x, it will available on z3x support or i have to download it from other place. thanks in advance : sanjubhai. |
lg vs820 Will there be any software soon to unlock the frp in the lg vs820 and the lg vs990? |
i have problem with lg vs425 |
i have problem.............. |
hi support can u add model x410hc Laf Protocol: 01000009 Model name: LM-X410HC Software verion: X41012b Android verion: 7.1.2 Target operator: LAO Target country: COM Chipset: mt6750 IMEI1: 355672090537884 IMEI2: 350305260000001 Detecting write method... Init write method... fail Init misc method... fail Init sign method... Execute sign method... done Checking sign method... Laf cmd info: send LAF_CMD_KILO, retry #1 Laf cmd info: send LAF_CMD_KILO, retry #2 Laf cmd info: send LAF_CMD_KILO, retry #3 Laf cmd error: LAF_CMD_KILO could not write. fail Laf flash error: phone is not supported. Elapsed: 73 secs. --> (v9.59) |
HELLO TEAM PLEASE REFUND MY CREDIT TNX TEAM 27.09.2022 14:47:35: Checking Login and Password... 27.09.2022 14:47:36: OK 27.09.2022 14:47:36: Ballance: 27.09.2022 14:47:36: 25 crd. 27.09.2022 14:47:41: You have 25 credit(s) left. This operation takes 10 credits.Continue? 27.09.2022 14:47:41: Yes 27.09.2022 14:47:54: Model name: LM-Q520N 27.09.2022 14:47:54: Software verion: Q520N30b 27.09.2022 14:47:54: Android verion: 12 27.09.2022 14:47:54: Target operator: LAO 27.09.2022 14:47:54: Target country: COM 27.09.2022 14:47:54: Chipset: mt6765 27.09.2022 14:47:54: IMEI: 352135740754229 27.09.2022 14:47:54: Serial: 0ALGDD24QYK003NXM 27.09.2022 14:47:54: Reading data from phone... 27.09.2022 14:47:56: OK 27.09.2022 14:47:56: Searching server... 27.09.2022 14:47:58: OK 27.09.2022 14:47:58: Waiting for server answer... 27.09.2022 14:47:59: OK 27.09.2022 14:47:59: Executing... 27.09.2022 14:48:15: OK 27.09.2022 14:48:15: Rebooting... 27.09.2022 14:48:21: OK 27.09.2022 14:48:21: Waiting phone... 27.09.2022 14:48:27: OK 27.09.2022 14:48:27: Phone found at COM525 27.09.2022 14:48:28: Model name: LM-Q520N 27.09.2022 14:48:28: Software verion: Q520N30b 27.09.2022 14:48:28: Android verion: 12 27.09.2022 14:48:28: Target operator: LAO 27.09.2022 14:48:28: Target country: COM 27.09.2022 14:48:28: Chipset: mt6765 27.09.2022 14:48:28: IMEI: 352135740754229 27.09.2022 14:48:28: Serial: 0ALGDD24QYK003NXM 27.09.2022 14:48:28: Reading data from phone... 27.09.2022 14:48:29: OK 27.09.2022 14:48:29: Executing... 27.09.2022 14:49:01: OK 27.09.2022 14:49:01: Done 27.09.2022 14:49:01: Elapsed: 80 secs. --> (v9.83) 27.09.2022 14:49:01: Login: zsc_1cwmXWeD |
Please refund my credit tnx team HELLO TEAM PLEASE REFUND MY CREDIT TNX TEAM 27.09.2022 14:47:35: Checking Login and Password... 27.09.2022 14:47:36: OK 27.09.2022 14:47:36: Ballance: 27.09.2022 14:47:36: 25 crd. 27.09.2022 14:47:41: You have 25 credit(s) left. This operation takes 10 credits.Continue? 27.09.2022 14:47:41: Yes 27.09.2022 14:47:54: Model name: LM-Q520N 27.09.2022 14:47:54: Software verion: Q520N30b 27.09.2022 14:47:54: Android verion: 12 27.09.2022 14:47:54: Target operator: LAO 27.09.2022 14:47:54: Target country: COM 27.09.2022 14:47:54: Chipset: mt6765 27.09.2022 14:47:54: IMEI: 352135740754229 27.09.2022 14:47:54: Serial: 0ALGDD24QYK003NXM 27.09.2022 14:47:54: Reading data from phone... 27.09.2022 14:47:56: OK 27.09.2022 14:47:56: Searching server... 27.09.2022 14:47:58: OK 27.09.2022 14:47:58: Waiting for server answer... 27.09.2022 14:47:59: OK 27.09.2022 14:47:59: Executing... 27.09.2022 14:48:15: OK 27.09.2022 14:48:15: Rebooting... 27.09.2022 14:48:21: OK 27.09.2022 14:48:21: Waiting phone... 27.09.2022 14:48:27: OK 27.09.2022 14:48:27: Phone found at COM525 27.09.2022 14:48:28: Model name: LM-Q520N 27.09.2022 14:48:28: Software verion: Q520N30b 27.09.2022 14:48:28: Android verion: 12 27.09.2022 14:48:28: Target operator: LAO 27.09.2022 14:48:28: Target country: COM 27.09.2022 14:48:28: Chipset: mt6765 27.09.2022 14:48:28: IMEI: 352135740754229 27.09.2022 14:48:28: Serial: 0ALGDD24QYK003NXM 27.09.2022 14:48:28: Reading data from phone... 27.09.2022 14:48:29: OK 27.09.2022 14:48:29: Executing... 27.09.2022 14:49:01: OK 27.09.2022 14:49:01: Done 27.09.2022 14:49:01: Elapsed: 80 secs. --> (v9.83) 27.09.2022 14:49:01: Login: zsc_1cwmXWeD |
Lg lm-k500um frp The operation was made, the credits gone. But still locked. I dont know if this is the right forum. Im so sorry if not Operation: FRP reset Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 10 credits.Continue? Yes Model name: LM-K500UM Software verion: K500UM20g Android verion: 11 Target operator: LAO Target country: COM Chipset: mt6765 IMEI: 356240972282166 Serial: WI06S201010000252 Reading data from phone... OK Searching server... OK Waiting for server answer... OK Executing... OK Rebooting... OK Waiting phone... OK Phone found at COM63 Model name: LM-K500UM Software verion: K500UM20g Android verion: 11 Target operator: LAO Target country: COM Chipset: mt6765 IMEI: 356240972282166 Serial: WI06S201010000252 Reading data from phone... OK Executing... OK Done Elapsed: 45 secs. --> (v9.83) |
