Old 04-25-2013, 11:55   #16 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
i9100 how to unlock(4.1.2)Jelly Bean
Selected model: I9100
Selected port:
Selected port speed: 115200
Reading phone info...
Model: GT-I9100
Android version: 4.1.2
Product code: GT-I9100LKANEE
Phone version: I9100XXLS8
PDA version: I9100XWLSJ
CSC version: I9100OXXLS7
IMEI: Unknown
Checking Super user right... false
Rooting phone, please wait... error
Done with Samsung Tool v.14.3
1)HOW TO UNLOCK 4.1.2(jelly bean)PHONE?
ANSWER)FIRST DOWNGRADE THE PHONE 4.0.4(Ice Cream Sandwich)
2)HOW TO DOWNGRADE 4.1.2 TO 4.0.4
ANSWER)DOWNLOAD THE PIT FILE&FLASH ROM
I9100_u1_02_20110310_emmc_EXT4.pit
I9100XWLPW_I9100ODDLPC_INU
THEN FLASH THE DEVICE
AFTER THE FLASH PHONE TRUN ON WAIT SOME MINUTES
WAIT LONG TIME
THEN NO MORE TIME WAIT
REMOVE THE BATTERY AFTER 1 MINUTES REINSERT PUT THE RECOVERY MODE(VOL+&HOME BUTTON&POWER BUTTON) THEN WIPE FACTORY RESET
AFTER RESET PHONE IS ALIVE
ENABLE DEBUG MODE CONNEECT USB THEN UNLOCK
Selected port:
Model: GT-I9100
Android version: 4.0.4
Phone version: I9100DDLPB
PDA version: I9100XWLPW
CSC version: I9100ODDLPC
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
NOTES,
i9100 4.1.2(jelly bean) MANNUL ROOT METHODE KILLED YOUR PHONE
AFTER ROOT PHONE IS BRICKSTHATS WHY I TRY THIS METHODE
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-25-2013, 12:08   #17 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
http://forum.gsmhosting.com/vbb/f453...-done-1635072/
plz check this link
Old 04-25-2013, 12:13   #18 (permalink)
Member: 351924
Originally Posted by saleem5001 View Post
bro i hope you dont read my post
what i say there
mannul root some time bricks the phone
befor unlock you mannul root the phone or not?:d
Old 04-30-2013, 10:33   #19 (permalink)
Member: 351924
How to unlock c3312 guide here
FIRST FLASH THE PHONE
HOW TO CONNECT C3312
HOLD VOLUM DOWN BUTTON INSERT THE USB CABLE
AFTER THE FLASH CANT DISCONNECT PHONE
WAIT FOR POWER ON,PHONE COME TO THE NORMAL CONIDTION
UNLOCK THEN PHONE
WITHOUT FLASHING CANT TRY THE UNLOCKING BECUZ WITHOUT FLASHING UNLOCK KILLED YOUR PROBLEM
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-30-2013, 10:44   #20 (permalink)
Member: 351924
How to unlock samsung s5830 phone with uart&usb cable
UART CABLE
Type *#7284# and choose phone UART
USB CABLE
Type *#7284# and choose phone USB
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-30-2013, 11:07   #21 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
what i say there
yes me root it via superuser and my fone done
The Following User Says Thank You to saleem5001 For This Useful Post:
Old 05-01-2013, 09:07   #22 (permalink)
Member: 351924
How to root and unlock samsung i8160
1)DOWNLOAD
I8160XXLD8_ready_to_root_ANT.tar.MD5
Odin3_v1.83
update_su
OPEN ODIN V1.83 SELECT I8160XXLD8_ready_to_root_ANT.tar.MD5 IN PDA PART,PUT THE PHONE DOWNLOAD MODE,CONNECT USB CABLE THEN FLASH IT,AFTER FLASH PUT ONE MEMORY CARD PASTE update_su
INSERT THIS MMC ON PHONE(PHONE MUST BE OFF)PUT THE PHONE TO RECOVERY MODE(VOLUM+&HOME BUTTON&POWER BUTTON)
Select "apply update from sdcard" and choose update_su.zip file
WAIT A SECONDS AND REBOOT PHONE
update_su
UNLOCK
POWER ON THE PHONE WITH BATTERY(NO SIM CARD)
ENABLE USB DEBUG MODE
ENTER THIS CODE *#7284#
UART AND USB SELECT MODEM
READ MORE INFORMATION ABOUT UNLOCK WITH SOFTWARE HELP
Selected model: I8160
Selected port: COM26 Z3X BOX Serial Port
Model: GT-I8160
Android version: 2.3.6
Product code: GT-I8160OKAXEC
Phone version: I8160BGLE2
PDA version: I8160BGLE2
CSC version: I8160XECLE2
IMEI: Unknown
Now connect phone to UART cable
Checking phone at COM26 OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Codes set to 00000000
Done
Old 05-02-2013, 12:07   #23 (permalink)
Member: 351924
Galaxy S4 i337 unlock
1 *#7284# select MODEM
2 *#9090# select 4 DM OVER UART
Uart cable s3350
in z3x samsung tool v14.2
choose i727 and read code
THANKS GO TO cado...............
Old 05-07-2013, 09:46   #24 (permalink)
Member: 351924
Android phones imei,network,insert sim(always flight mode)solution here
SAMSUNG IMEI,NETWORK,INSERT SIM(FLIGHT MODE ONLY)NOT 100%SOFTWARE DEFECT
HOW TO CHECK PROBLEM HARDWARE OR SOFTWARE
1)POWER THE PHONE WITHOUT SIM CARD ENTER *#06#
IMEI SHOW
IMEI: 004999010640000
(SOLUTION)
1)ENABLE USB DEBUG MODE ALSO READ INSTRUCTION FROM SOFTWARE HELP
2)REBUILD IMEI WITH Z3X
2)IMEI SHOW LIKE THIS?
(SOLUTION)
2)REBUILD IMEI AND REPAIR EFS WITH Z3X
WHILE REBUILD IMEI GOT THIS ERROR?
NO MORE TRY IMEI REBUILDING AND EFS REPAIR WITH Z3X
TRY TO WRITE EFS WITH JTAG
http://forum.gsmhosting.com/vbb/8816284-post5.html
AFTER WRITE THE EFS IMEI COME TO THEN TRY TO FIX THE IMEI(STEP@1)
AFTER WRITE THE EFS FILE WITH JTAG IMEI STILL SAME NULL CONDITION NO NEED TO MORE TRY WITH SOFTWARE PROBLEM GO TO
HARDWARE
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-07-2013, 16:18   #25 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
WAIT LONG TIME
NOTES,
need to check re-partiton or not ?????????
Old 05-09-2013, 11:09   #26 (permalink)
Member: 351924
bro use the pit file
re-partiton(need to check)
then downgrade the phone
File Type: rar I9100_u1_02_20110310_emmc_EXT4.rar (446 Bytes, 65 views)
Old 05-09-2013, 13:03   #27 (permalink)
Member: 1737671
Thanks Meter: 69
Good job bro really helpfull Note
Old 05-17-2013, 10:39   #28 (permalink)
Member: 351924
How to imei rebuild samsung star duos c6712
FLASH THE PHONE WITH ANY VERSION
AFTER THE FLASH CANT DISCONNECT THE PHONE WITH USB(WAIT 30SECONDS PHONE COME TO NORMAL CONDITION)
FILL CORRECT IMEI NUMBER
USE CUSTOM OPTION
Selected model: C6712
Selected com port: COM7
Selected speed port: 921600
Phone must be ON
Search modem ... OK
Search modem on:COM41
Phone OLD SN: 0000000000
Phone OLD IMEI: 00000000000000 /0
Phone OLD slave IMEI: 00000000000000 /0
Phone SW: C6712XXKF3
Search flash modem ...
Search flash modem ... OK
Search flash modem on:COM26
Send loader... OK
Wait for boot ...
Send loader... OK
Wait for boot ...
Phone must be ON
Search modem ... OK
Search modem on:COM24
Phone NEW SN: 0000000000
MSL DEACTIVATED - TRUE
Write imei - ok
Phone NEW IMEI: 35569304143034 /2
Phone NEW slave IMEI: 35620904143034 /6
Elapsed time: 114 second, sw ver: 3.5.0040
Notes
You Must Flash The Phone Befor Imei Rebuild
Or
You Must Select Phone Same Version APPS file
When You Selected Different Version APPS file While REBUILD Imei Phone Go To Software Bricks
[IMG]**************************************/images?q=tbn:ANd9GcS__GnWn5IQSPWfGQi9URhmTpgS3OEFm UaVpLQo-r-jkf58X9zg[/IMG]
Old 05-17-2013, 12:30   #29 (permalink)
Member: 351924
How to format samsung spd phones
Old 05-18-2013, 09:13   #30 (permalink)
Member: 351924
i9300&N7100 Product Name(NULL)
i9300,N7100 Phones Suck On Samsung Logo Only
Put The Phone Download Mode(ODIN MODE)
check Product Name Show Or Not
Product Name Is NULL
Problem Not a Software Side
No Need To Flash The Phone.
Problem Go To Bad EMMC
FAQ - LG Phones. Souhail Z3X-Team Products 12 12-15-2022 19:53
-== Total Samsung Tool 1.03 ==- A COMPLETE SOLUTION FOR NEW SAMSUNG PHONES SiRoYa Main Sales Section 0 03-12-2005 14:55
new support for samsung i series and samsung phone card gc 82 badil Twisterflasher 0 12-10-2004 16:15
Page generated in 0.32849 seconds with 11 queries
