04-25-2013, 11:55 | #16 (permalink) | ||
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | i9100 how to unlock(4.1.2)Jelly Bean Quote:
ANSWER)FIRST DOWNGRADE THE PHONE 4.0.4(Ice Cream Sandwich) 2)HOW TO DOWNGRADE 4.1.2 TO 4.0.4 ANSWER)DOWNLOAD THE PIT FILE&FLASH ROM I9100_u1_02_20110310_emmc_EXT4.pit I9100XWLPW_I9100ODDLPC_INU THEN FLASH THE DEVICE AFTER THE FLASH PHONE TRUN ON WAIT SOME MINUTES WAIT LONG TIME THEN NO MORE TIME WAIT REMOVE THE BATTERY AFTER 1 MINUTES REINSERT PUT THE RECOVERY MODE(VOL+&HOME BUTTON&POWER BUTTON) THEN WIPE FACTORY RESET AFTER RESET PHONE IS ALIVE ENABLE DEBUG MODE CONNEECT USB THEN UNLOCK Quote:
i9100 4.1.2(jelly bean) MANNUL ROOT METHODE KILLED YOUR PHONE AFTER ROOT PHONE IS BRICKSTHATS WHY I TRY THIS METHODE | ||
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
04-25-2013, 12:08 | #17 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | http://forum.gsmhosting.com/vbb/f453...-done-1635072/ plz check this link |
04-25-2013, 12:13 | #18 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
what i say there mannul root some time bricks the phone befor unlock you mannul root the phone or not?:d | |
04-30-2013, 10:33 | #19 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | How to unlock c3312 guide here FIRST FLASH THE PHONE HOW TO CONNECT C3312 HOLD VOLUM DOWN BUTTON INSERT THE USB CABLE AFTER THE FLASH CANT DISCONNECT PHONE WAIT FOR POWER ON,PHONE COME TO THE NORMAL CONIDTION UNLOCK THEN PHONE WITHOUT FLASHING CANT TRY THE UNLOCKING BECUZ WITHOUT FLASHING UNLOCK KILLED YOUR PROBLEM |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
04-30-2013, 10:44 | #20 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | How to unlock samsung s5830 phone with uart&usb cable UART CABLE Type *#7284# and choose phone UART USB CABLE Type *#7284# and choose phone USB |
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
05-01-2013, 09:07 | #22 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | How to root and unlock samsung i8160 1)DOWNLOAD I8160XXLD8_ready_to_root_ANT.tar.MD5 Odin3_v1.83 update_su OPEN ODIN V1.83 SELECT I8160XXLD8_ready_to_root_ANT.tar.MD5 IN PDA PART,PUT THE PHONE DOWNLOAD MODE,CONNECT USB CABLE THEN FLASH IT,AFTER FLASH PUT ONE MEMORY CARD PASTE update_su INSERT THIS MMC ON PHONE(PHONE MUST BE OFF)PUT THE PHONE TO RECOVERY MODE(VOLUM+&HOME BUTTON&POWER BUTTON) Select "apply update from sdcard" and choose update_su.zip file WAIT A SECONDS AND REBOOT PHONE I8160XXLD8_ready_to_root_ANT.tar.MD5 update_su UNLOCK POWER ON THE PHONE WITH BATTERY(NO SIM CARD) ENABLE USB DEBUG MODE ENTER THIS CODE *#7284# UART AND USB SELECT MODEM READ MORE INFORMATION ABOUT UNLOCK WITH SOFTWARE HELP Quote:
05-02-2013, 12:07 | #23 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Galaxy S4 i337 unlock Quote:
05-07-2013, 09:46 | #24 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Android phones imei,network,insert sim(always flight mode)solution here SAMSUNG IMEI,NETWORK,INSERT SIM(FLIGHT MODE ONLY)NOT 100%SOFTWARE DEFECT HOW TO CHECK PROBLEM HARDWARE OR SOFTWARE 1)POWER THE PHONE WITHOUT SIM CARD ENTER *#06# IMEI SHOW Code: IMEI: 004999010640000 1)ENABLE USB DEBUG MODE ALSO READ INSTRUCTION FROM SOFTWARE HELP 2)REBUILD IMEI WITH Z3X 2)IMEI SHOW LIKE THIS? (SOLUTION) 1)ENABLE USB DEBUG MODE ALSO READ INSTRUCTION FROM SOFTWARE HELP 2)REBUILD IMEI AND REPAIR EFS WITH Z3X WHILE REBUILD IMEI GOT THIS ERROR? NO MORE TRY IMEI REBUILDING AND EFS REPAIR WITH Z3X TRY TO WRITE EFS WITH JTAG http://forum.gsmhosting.com/vbb/8816284-post5.html AFTER WRITE THE EFS IMEI COME TO THEN TRY TO FIX THE IMEI(STEP@1) AFTER WRITE THE EFS FILE WITH JTAG IMEI STILL SAME NULL CONDITION NO NEED TO MORE TRY WITH SOFTWARE PROBLEM GO TOHARDWARE |
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
05-07-2013, 16:18 | #25 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | Quote:
05-17-2013, 10:39 | #28 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | How to imei rebuild samsung star duos c6712 FLASH THE PHONE WITH ANY VERSION AFTER THE FLASH CANT DISCONNECT THE PHONE WITH USB(WAIT 30SECONDS PHONE COME TO NORMAL CONDITION) FILL CORRECT IMEI NUMBER USE CUSTOM OPTION Quote:
You Must Flash The Phone Befor Imei Rebuild Or You Must Select Phone Same Version APPS file When You Selected Different Version APPS file While REBUILD Imei Phone Go To Software Bricks [IMG]**************************************/images?q=tbn:ANd9GcS__GnWn5IQSPWfGQi9URhmTpgS3OEFm UaVpLQo-r-jkf58X9zg[/IMG] | |
05-18-2013, 09:13 | #30 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | i9300&N7100 Product Name(NULL) i9300,N7100 Phones Suck On Samsung Logo Only Put The Phone Download Mode(ODIN MODE) check Product Name Show Or Not Product Name Is NULL Problem Not a Software Side No Need To Flash The Phone. Problem Go To Bad EMMC |
FAQ - LG Phones. | Souhail | Z3X-Team Products | 12 | 12-15-2022 19:53 |
-== Total Samsung Tool 1.03 ==- A COMPLETE SOLUTION FOR NEW SAMSUNG PHONES | SiRoYa | Main Sales Section | 0 | 03-12-2005 14:55 |
new support for samsung i series and samsung phone card gc 82 | badil | Twisterflasher | 0 | 12-10-2004 16:15 |
