Old 05-18-2013, 09:29   #31 (permalink)
.::intel32::.'s Avatar
Member: 350719
Sonork: 100.1623850
Thanks Meter: 158
Thumbs down
T999 unlock done
1 ROOT THE phone(CF-Root Download)
2 Enable usb debug
3 Enter "*#7284#" ( DO NOT SELECT MODEM )
4 Go to "Qualcomm USB Settings".
5 Select "DM + Modem + ADB". save
6 Wait till drivers be installed...
7 select port
8 Press unlock.
Old 05-18-2013, 13:21   #32 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Galaxy S4 i337 Read Code
1 *#7284# select MODEM
2 *#9090# select 4 DM OVER UART
Uart cable s3350
choose i727 and read code
Selected model: I727
Selected port: COM6 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Build: M9615A-CEFWTAZM-4.0.17062
Reading security... OK
Searching server... OK
NET lock: #7465625*638*40617046#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
Done with Samsung Tool v.14.2
thanks go to ...........*cado
Old 05-21-2013, 06:08   #33 (permalink)
Member: 351924
How To Root and Unlock Galaxy S4 I9500
1- Just Activate Debug Mode For First
http://www.youtube.com/watch?v=ieuap9Ec-J8
2-Now root your device and this is web site explaining it with CWM for rooting
How to Root Samsung Galaxy S4 I9500 (Exynos 5) on Android 4.2.2 XXUAMDE Jelly Bean [GUIDE] [VIDEO] - IBTimes UK
http://www.youtube.com/watch?v=SajfKZBjvuQ
xda-developers - View Single Post - [GT-i9500] cofface CWM 6.0.3.2 RECOVERY & ROOT (EASY and WORKING) New update
After The Root
Just Read Info Of Your Device
Click autorisation and read EFS
Now CLICK ON UNLOCK
Selected model: I9500
Selected port: COM87 Z3X BOX Serial Port
Model: GT-I9500
Android version: 4.2.2
Product code: GT-I9500ZWAMED
Phone version: I9500XXUAMDE
PDA version: I9500XXUAMDE
CSC version: I9500OJVAMDC
IMEI: Unknown
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool v.14.5
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-21-2013, 06:29   #34 (permalink)
Member: 351924
How To Read Unlock Code Samsung I317M (Rogers Canada)
Type *#7284# and choose "Modem" for both options.
Type *#9090# and choose "[1]DM\DUM over HS-USB(*)"
Then Connect Phone with (Nokia 5130) Micro USB Cable (Not UART RJ45 Micro USB Cable)
Select I317M in Z3x Software
Select "COMxx Qualcomm HS-USB Diagnostics 9004" in Z3X Software
Selected model: I317M
Selected port: COM51 Qualcomm HS-USB Diagnostics 9004
Build: M9615ACEHWMAZD17515030
NET lock: #7465625*638*90420483#
Done with Samsung Tool v.13.9
thanks go to @gsm_surya
Old 05-23-2013, 15:10   #35 (permalink)
Member: 1291068
how to unlock samsung GH-B3410 with Z3X?
Thinks
Old 06-18-2013, 12:37   #36 (permalink)
Member: 755916
Thanks Meter: 28
Hi Team;
after using cmd "adb reboot recovery" to S5570i the phone stuck in Recovery mode screen. Now i can not exit this mode because home button stop working also phone refuse to enter in download mode.
PS : Phone is new and all buttons work before
Old 06-20-2013, 05:38   #37 (permalink)
Member: 351924
Sc-03e ntt docomo unlock mannul here
STEP 1-POWER ON THE PHONE WITHOUT SIMCARD
THEN ENTER ENTER *#9090#&*#7284#
AFTER ENTER THIS CODE PHONE CANT ENTER THE SERVICE MODE AND PHONE UTIL MODE?
LIKE THIS PICTURE?!!!!?
STEP-2 GO TO SETTINGS+CHANGE HOME THEN SELECT 'TOUCHWIZ BASIC MODE'
LIKE THIS PICTURES
STEP-3 ENTER THIS CODE "*#7284#"
USB SELECT TO PAD
GO TO "Qualcomm USB Settings"
SELECT "RNDIS+DM+MODEM"
SAVE AND RESTART THE PHONE.
STEP-4 AGAIN TO ENTER THIS CODE *#9090#
PHONE ENTER SERVICE MODE
SELECT THE OPTION "DM/UM over HS-USB"
RESTART THE PHONE
STEP-5 GO TO DEVICE MANAGER+PORT THEN CHECK PHONE COMPORT,THIS SAME COMPORT SELECT Z3X 3G TOOL AND USE READ CODES OPTION
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-20-2013, 05:44   #38 (permalink)
ub
ub's Avatar
Member: 1757379
Sonork: no need
Thanks Meter: 400
booommmmmmmmmmmmmmmmmmmmmmmmmmmmm z3x it always best
Old 06-20-2013, 09:07   #39 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 3,001
http://forum.gsmhosting.com/vbb/f453...oblam-1674403/
Old 06-20-2013, 10:57   #40 (permalink)
Member: 1896924
Sonork: 10122012
Thanks Meter: 5
Thanks goooooooooooooooooooooooooooooood
Old 06-21-2013, 06:44   #41 (permalink)
GsmExpertz.Clt's Avatar
Member: 74036
Sonork: 100.1601291
Thanks Meter: 42
Originally Posted by shijilfonotly View Post
i9300,n7100 phones suck on samsung logo only
put the phone download mode(odin mode)
check product name show or not
product name is null
problem not a software side
no need to flash the phone.
problem go to bad emmc
very nice information, very good
Old 06-21-2013, 10:20   #42 (permalink)
Member: 351924
AT&T SAMSUNG i437 UNLOCKED VIA UART CABLE(MANNUL HERE)
Enter *#7284# number.
Set UART to PDA value.
Enter *#9090# number.
Set Diag config to UART value.
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-21-2013, 11:50   #43 (permalink)
Member: 351924
How to unlock samsung s3572 duos(tips here)
OPEN Z3X 3G TOOL
SELECT S3572 MODEL
USE C3303 UART CABLE
CONNECT THE PHONE WITHOUT BATTERY
USE UNLOCK OR READ CODE
WHILE START THE PROCESS JUST INSERT BATTERY,WITH IN 10SECONDS PHONE ENTER TAT MODE THEN WAIT FOR THE UNLOCK
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-21-2013, 12:17   #44 (permalink)
Member: 351924
How to Flash samsung s3572 duos(tips here)
DOWNLOAD FLASH FILE FROM SUPPORT.
SELECT MODEL AND FLASH FILES
CONNECT PHONE WITH USB CABLE(WITHOUT BATTERY)
WHILE START THE FLASHING JUST INSERT THE BATTERY
Selected model: S3572
Selected port:
Selected port speed: 921600
Reconnect battery and connect phone to USB cable
Phone detected
Opening device... OK
Checking device descriptions... OK
Device description: 04CC 0409
Checking config descriptor... OK
Reading OTP register... OK
OTP register: 473E8100
Reading product ID... OK
Product ID: 0001D50700000000
Reading SCROM version... OK
SCROM version: 0x31
Chipset version: 0x48
Sending loader... OK
Start loader... OK
Waiting phone... OK
Reading loader version... OK
Loader version: 7.5.16
Init Flash... OK
Loading flash info... OK
Configure Flash... OK
Erase memory for external loader... OK
Sending external loader... OK
Start external loader... OK
Waiting phone... OK
Init Flash... OK
Load flash info... OK
Configure Flash... OK OK
Loading PTT file... OK
Reading first block... OK
Erasing first block... OK
Flashing first block... OK
Init bad block... OK
Erasing IMAGE... OK
Erasing LCDACT... OK
Erasing DATA_RW... OK
Erasing DSP... OK
Erasing PAGE... OK
Erasing MAIN... OK
Erasing a... OK
Erasing b... OK
Erasing c... OK
Erasing d... OK
Erasing OTPW... OK
Writing IMAGE... OK
Writing LCDACT... OK
Writing DATA_RW... OK
Writing DSP... OK
Writing PAGE... OK
Writing MAIN... OK
Writing a... OK
Writing b... OK
Writing c... OK
Writing d... OK
Writing OTPW... OK
Rebooting... done
Flashing done (time - 00:03:24)
Done with Samsung Tool v.14.7
Old 06-25-2013, 14:24   #45 (permalink)
Member: 351924
CAREFULY UNLOCK samsung S6810P,S6810L
samsung S6810P,S6810L Used Two Types Of Security Old And New
New Security Phone Cant Unlock Below 14.9 Software Version
OtherWise New Security Phone Go To Dead After The Unlock
Make Sure Using SOftware 14.9
How To Alive The Dead Phone
MUST USE Jtag No other Way to Repair this Phone
Thank You For The Understanding
FAQ - LG Phones. Souhail Z3X-Team Products 12 12-15-2022 19:53
-== Total Samsung Tool 1.03 ==- A COMPLETE SOLUTION FOR NEW SAMSUNG PHONES SiRoYa Main Sales Section 0 03-12-2005 14:55
new support for samsung i series and samsung phone card gc 82 badil Twisterflasher 0 12-10-2004 16:15
Page generated in 0.31067 seconds with 11 queries
