FAQ - Samsung phones. SOFTBANK 730SC, 821SC, 820SC UNLOCK READ This before Flash firmware Important! Don't flash CAMERA Patch before unlock. If you flash camera patch before unlock then flash back normal firmware and UNLOCK. Q. Why after unlock my country have 3G network but phone is always no signal? A. Flash to unlocked phone "730SCIA3_camera_patch.crp" then your phone can get 3G network. Q. Please tell me how to write FW step by step. A. Flashing firmware only via USB cable - can use 2in1 cable or original cable from phone box. Steps: 1 - switch power your phone to boot mode ( * + power ). 2 - Select Model 730SC 3 - Select Firmware 4 - Connect USB cable to your phone, and setup driver from folder x:\program files\z3x\samsung\qualcomm\samsung drivers\ 5 - Click " Search phone " if SW can not detect USB port remove USB cable from phone and reconnect, go step 5 again 6 - Click " Update frimware " 7 - Confirm window will appear then click YES. 8 - Wait Done and will reboot itself. Don't try to phone more older version, you will have error. Q. Always get ERROR when unlocking. A. Connect ONLY RJ45(com cable) then unlock again. Unlocking only via COM parts of 2in1 cable. Q. Put com cable only but " unable to find phone " why? A. Check com cable. May reverse TX and RX line. 821SC Softbank Unlock w/ camera ok Cable used:E210 Procedure: 1.Connect E210 cable usb/rj 45 2.Check 2 in 1 cable & Qualcomm mode 3.Search phone 4.Press unlock After unlock success.. Next step (Flashing) 1. download multimidia & network unlock patch and load 2. removed rj45( use usb only ) 3. hold * + power on 4. install all phone driver if needed 5. ticked update firmware note: wait until phone rebot as normal |
UNLOCKING PROCEDURE 930SC, 931SC, 740SC SOFTBANK 1. Check phone battery. Must be Full. 2. Switch phone to boot mode: Volume key down + camera button + power on 3. Connect phone to usb data cable and setup driver. 3. Flash unlock+camera patch fw to phone. Enjoy and wait next BomB updates from Z3X-TEAM |
UNLOCKING PROCEDURE 805SC, 705SS, 707SC, 707SC2 SOFTBANK 1. Check phone battery. Must be Full. 2. Power on phone. 3. Connect RG45 part of cable to box. 4. Run QTool, choise 805sc and press unlock. IMPORTANT: If after unlocking 805SC you got blink on lcd, reflash your phone. |
930SC DOWNLOAD MODE DRIVER PROBLEM Q: Where i can get Qualcom cdma technologies msm driver for download mode of 930SC. A: First uninstall I900 driver and then attach 930SC in download mode and install driver from ''X:/program files/z3x/samsung/qualcomm''. |
SoftBank 930SC - unlock procedure via Z3X-Box SoftBank 930SC - unlock procedure full manual step by step + screenshots Requirements: - Download file PATCH "930SCHL4_unlock_and_media.zip" FTP manufacturer or www.ligtelgsm.com.br (members only) - Required 730SC cable RJ45 + USB - Use program Samsung Qualcomm Tool version 5.6.42 or higher - Battery 100% charged STEP 1 (How to put the phone in DOWNLOAD) 1 - Phone with battery and connected off WITHOUT CABLE 2 - Switch phone to flash mode: Volume key down + camera button + power on 3 - It will be shown on the phone display the following information: 930SC 2:00 DOWNLOAD 4 - If it asks for the drivers phone, just look for the drivers in the following folder C: \ Program Files \ Z3X \ Samsung \ Qualcomm \ Samsung Drivers STEP 2 (How to unlock the phone) 1 - Open the Samsung Qualcomm Tool 5.6.42 or higher 2 - Choose Model 930SC 3 - Double click on the field FIRMWARE and select the file "930SCHL4_unlock_and_media.crp" 4 - The Information (type, version and type) of the file will be displayed by the program. 5 - Click on the UPDATE FIRMWARE http://www.ligteltelecom.com.br/foru...C_UNLOCK_1.JPG 6 - This will display a confirmation window, just click YES http://www.ligteltelecom.com.br/foru...C_UNLOCK_2.JPG 7 - Wait for the flash finish 8 - After the message "Done Flashing" wait for the phone restart, remove the cable and test the release. http://www.ligteltelecom.com.br/foru...C_UNLOCK_3.JPG |
VIDEO ..::Unlock GT-S8000 By Z3X::.. http://img51.imageshack.us/img51/6346/s8000picture2.jpg - Requires program Samsung_Qualcomm_Tool_6.3.01 - Require PATCH S8000XEIG2_patched_for_unlock. - Necessary data cable original V8. - Phone off with battery (without the USB cable connected to the phone) Here is the video with instructions http://www.megaupload.com/?d=58AXSLDE Greetings ..::X-C-X::.. |
GT-i7500 Galaxy imei repair direct unlock Manual: 1. First goto Menu - Settings-> Applications-> Developlent - ( switch on ) USB debuging ON 2. Type: *#197328640# goto 9 common - 4 diag-hfk_configuration - 1 uart_null_usb_diag 3. Install drivers from z3x driver folder. 4. Choise i7500 from list - press unlock or imei repair. |
709sc unlocked 1 Attachment(s) choose file 709CHE1 connect in bootloader mode, 9+ power flash unlock |
HOW TO FLASH SAMSUNG DUOS LIKE C5212 select c5212_m select settings model then choose Flash Mode flash only the master flashes: C5212XAIC_Master.cla C5212XAIC_Master.tfs next select c5212_s select settings model then choose Flash Mode flash only the slave flashes: C5212XAIC_Slave.cla C5212XAIC_Slave.tfs at the end with phone on, check imei with *#06# if any imei is at 000000000000000 fill the imei field with correct imei on the label and select/click repair custom remember 1st imei is master (c5212_m) and 2nd imei is slave ( c5212_s) |
PROCEDURE UNLOCK SAMSUNG A887 1. put original simcard ( ex. at&t card ) 2. Power on phone. 3. Type *#197328640# -> common -> usb config -> Qualcomm mode 4. Connect USB cable, setup drivers. 5. Choise qualcomm 6. Choise unlock method: Read codes 7. Press Unlock SP button. ** USE USB CABLE FOR E210 Model: SGH-A887 CountryCode: ATT Factory SW: UCIJ1 UniqueNumber: 80110000257544 MemoryPhone: K5R2G1GACC(A887)S IMEI: 35704403855674/9 Phone S/N: RU1Z195597 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error ================> YOU WILL GET ERROR, relax... Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:13) Freeze code: 06927139 NET lock: #7465625*638*28203693# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.3 ===> use this soft br, VODAFONES |
UNLOCK SAMSUNG SOFTBANK 920SC 1. Power on phone. 2. Connect RJ45 (COM) cable. 3. Choise unlock method: Unlock or Relock. 4. Choise port of RJ45 connector in port settings 5. Press Unlock SP button. 6. Flash media and network patch firmware. 1. Switch phone to flash mode (*+#). 2. Connect USB cable and choise correct fw files. 3. Press update firmware button. FLASH WITH : 920SCHF3_camera_and_media_patch.crp ----------------------------- Model: SGH-V920 CountryCode: SBM Factory SW: 920SCGL8 UniqueNumber: 70540000123873 MemoryPhone: KBE00S00AB(V920) IMEI: 35166202030668/6 Phone S/N: R3YQ108220 Build: M6280A-KLRZ-4.0.5080 Done with Samsung 3G tool ver 9.3 Reading file... OK Model: 920SC Version: 920SCHF3 Info: camera and media patch Searching Samsung USB Flash interface... not found Reading file... OK Model: 920SC Version: 920SCHF3 Info: camera and media patch Searching Samsung USB Flash interface... not found Reading file... OK Model: 920SC Version: 920SCHF3 Info: camera and media patch Searching Samsung USB Flash interface... detected (COM98) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:05:50) Done with Samsung 3G tool ver 9.3 br, VODAFONES |
Samsung galaxy y S5360 android v2.3.6 unlock done Samsung galaxy young s5360 android v2.3.6 unlock done step by step. SMART provider. Tools: z3x box Samsung tool v12.1 mini usb Procedure: how to root Samsung galaxy y android v2.3.6 *dowload update zip http://dl.xda-developers.com/attachd...8/8/update.zip *copy and paste the update zip file to the root of the micro sd scard. do not extract. *rooting phone procedure/ insert micro sd card to phone. press volume up,home and power button. http://img690.imageshack.us/img690/4980/15032012314.jpg wait until phone turn into recovery mode then select apply update from sd card using volume up or down button. http://img210.imageshack.us/img210/5449/12032012271.jpg select update_2.zip http://img9.imageshack.us/img9/3362/12032012272.jpg select reboot system now. http://img28.imageshack.us/img28/753/12032012273.jpg after rebooting unlock procedure: open samsung tool v 12.1 select correct model select correct com port select read codes and unlock. http://img193.imageshack.us/img193/6949/88389411.png while unlocking the phone superuser request pop up on the screen of the phone just select allow only. http://img833.imageshack.us/img833/9219/12032012274.jpg wait until unlocking finish then turn off the phone, turn on the phone with sim card input NCK codes wait till unlocking successful. http://img687.imageshack.us/img687/6657/12032012281.jpg testing |
Note: not compatible security S7250 and S7250D If you flash in S7250 patch apps from S7250D - after flash (imei not activ) and logs soft 1234567891234 - need after read code flash original apps S7250 and imei will be ok. And vice versa(flash in S7250D apps from S7250). |
1 - Flash your S7250 with S7250D firmware from support (S7250DXXKK1_OXE) without bootfiles 2 - Flash your phone with apps_patch_S7250DXEKK1.bin from support 3 - Read codes you get NCK code (save them you will use it) 4 - You got bad IMEI, d'ont worry 5 - Reflash your S7250 with original firmware or this one (S7250XXKK1_S7250OXAKK1_DBT, from support), if there is no FFS file use one of (S7250DXXKK1_OXE):FactoryFs_S7250D_Open_Europe_Com mon.ffs 6 - Enter your NCK code calculated on step 3 7 - Unlock Done, true IMEI 8 - D'ont forget THANKS |
thanks bro for sharing d wonderful information..... |
