Old 04-24-2009, 12:25   #1 (permalink)
andy_jpn's Avatar
Member: 248942
Sonork: 100.1590361
Thanks Meter: 455
FAQ - Samsung phones.
SOFTBANK 730SC, 821SC, 820SC UNLOCK
READ This before Flash firmware
Important!
Don't flash CAMERA Patch before unlock.
If you flash camera patch before unlock then flash back normal firmware and UNLOCK.
Q. Why after unlock my country have 3G network but phone is always no signal?
A. Flash to unlocked phone "730SCIA3_camera_patch.crp" then your phone can get 3G network.
Q. Please tell me how to write FW step by step.
A. Flashing firmware only via USB cable - can use 2in1 cable or original cable from phone box.
Steps:
1 - switch power your phone to boot mode ( * + power ).
2 - Select Model 730SC
3 - Select Firmware
4 - Connect USB cable to your phone,
and setup driver from folder x:\program files\z3x\samsung\qualcomm\samsung drivers\
5 - Click " Search phone "
if SW can not detect USB port remove USB cable from phone and reconnect, go step 5 again
6 - Click " Update frimware "
7 - Confirm window will appear then click YES.
8 - Wait Done and will reboot itself.
Don't try to phone more older version, you will have error.
Q. Always get ERROR when unlocking.
A. Connect ONLY RJ45(com cable) then unlock again. Unlocking only via COM parts of 2in1 cable.
Q. Put com cable only but " unable to find phone " why?
A. Check com cable. May reverse TX and RX line.
821SC Softbank Unlock w/ camera ok
Cable used:E210
Procedure:
1.Connect E210 cable usb/rj 45
2.Check 2 in 1 cable & Qualcomm mode
3.Search phone
4.Press unlock
After unlock success..
Next step (Flashing)
1. download multimidia & network unlock patch and load
2. removed rj45( use usb only )
3. hold * + power on
4. install all phone driver if needed
5. ticked update firmware
note: wait until phone rebot as normal
The Following 79 Users Say Thank You to andy_jpn For This Useful Post:
Old 06-04-2009, 10:19   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 177,861
UNLOCKING PROCEDURE 930SC, 931SC, 740SC SOFTBANK
1. Check phone battery. Must be Full.
2. Switch phone to boot mode:
Volume key down + camera button + power on
3. Connect phone to usb data cable and setup driver.
3. Flash unlock+camera patch fw to phone.
Enjoy and wait next BomB updates from Z3X-TEAM
The Following 42 Users Say Thank You to blang For This Useful Post:
Old 06-04-2009, 10:33   #3 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
UNLOCKING PROCEDURE 805SC, 705SS, 707SC, 707SC2 SOFTBANK
2. Power on phone.
3. Connect RG45 part of cable to box.
4. Run QTool, choise 805sc and press unlock.
IMPORTANT: If after unlocking 805SC you got blink on lcd, reflash your phone.
The Following 26 Users Say Thank You to blang For This Useful Post:
Old 06-06-2009, 10:53   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
930SC DOWNLOAD MODE DRIVER PROBLEM
Q: Where i can get Qualcom cdma technologies msm driver for download mode of 930SC.
A: First uninstall I900 driver and then attach 930SC in download mode and install driver from ''X:/program files/z3x/samsung/qualcomm''.
Old 09-30-2009, 21:35   #5 (permalink)
Cheater -Don't Deal with him-
Member: 85712
Thanks Meter: 131
SoftBank 930SC - unlock procedure via Z3X-Box
SoftBank 930SC - unlock procedure full manual step by step + screenshots
Requirements:
- Download file PATCH "930SCHL4_unlock_and_media.zip" FTP manufacturer or www.ligtelgsm.com.br (members only)
- Required 730SC cable RJ45 + USB
- Use program Samsung Qualcomm Tool version 5.6.42 or higher
- Battery 100% charged
STEP 1 (How to put the phone in DOWNLOAD)
1 - Phone with battery and connected off WITHOUT CABLE
2 - Switch phone to flash mode:
3 - It will be shown on the phone display the following information:
930SC
2:00 DOWNLOAD
4 - If it asks for the drivers phone, just look for the drivers in the following folder C: \ Program Files \ Z3X \ Samsung \ Qualcomm \ Samsung Drivers
STEP 2 (How to unlock the phone)
1 - Open the Samsung Qualcomm Tool 5.6.42 or higher
2 - Choose Model 930SC
3 - Double click on the field FIRMWARE and select the file "930SCHL4_unlock_and_media.crp"
4 - The Information (type, version and type) of the file will be displayed by the program.
5 - Click on the UPDATE FIRMWARE
6 - This will display a confirmation window, just click YES
7 - Wait for the flash finish
8 - After the message "Done Flashing" wait for the phone restart, remove the cable and test the release.
The Following 19 Users Say Thank You to ligteltelecom For This Useful Post:
Old 01-10-2010, 19:31   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
VIDEO ..::Unlock GT-S8000 By Z3X::..
- Requires program Samsung_Qualcomm_Tool_6.3.01
- Require PATCH S8000XEIG2_patched_for_unlock.
- Necessary data cable original V8.
- Phone off with battery (without the USB cable connected to the phone)
Here is the video with instructions
http://www.megaupload.com/?d=58AXSLDE
Greetings
..::X-C-X::..
The Following 17 Users Say Thank You to blang For This Useful Post:
Old 01-10-2010, 20:16   #7 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
GT-i7500 Galaxy imei repair direct unlock Manual:
1. First goto Menu - Settings-> Applications-> Developlent - ( switch on ) USB debuging ON
2. Type: *#197328640# goto 9 common - 4 diag-hfk_configuration - 1 uart_null_usb_diag
3. Install drivers from z3x driver folder.
4. Choise i7500 from list - press unlock or imei repair.
The Following 18 Users Say Thank You to blang For This Useful Post:
Old 05-11-2010, 10:47   #8 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 141
709sc unlocked
choose file 709CHE1
connect in bootloader mode, 9+ power
flash
unlock
The Following 5 Users Say Thank You to akkay For This Useful Post:
Old 01-08-2011, 12:16   #9 (permalink)
CMV_2K's Avatar
Member: 9709
Thanks Meter: 32
HOW TO FLASH SAMSUNG DUOS LIKE C5212
select c5212_m
select settings model then choose Flash Mode
flash only the master flashes:
C5212XAIC_Master.cla
C5212XAIC_Master.tfs
next
select c5212_s
flash only the slave flashes:
C5212XAIC_Slave.cla
C5212XAIC_Slave.tfs
at the end with phone on, check imei with *#06#
if any imei is at 000000000000000
fill the imei field with correct imei on the label and select/click repair custom
remember 1st imei is master (c5212_m) and 2nd imei is slave ( c5212_s)
Old 01-18-2011, 12:54   #10 (permalink)
VODAFONES's Avatar
Member: 747968
Sonork: 100.1621353
Thanks Meter: 444
PROCEDURE UNLOCK SAMSUNG A887
1. put original simcard ( ex. at&t card )
2. Power on phone.
3. Type *#197328640# -> common -> usb config -> Qualcomm mode
4. Connect USB cable, setup drivers.
5. Choise qualcomm
6. Choise unlock method: Read codes
7. Press Unlock SP button.
** USE USB CABLE FOR E210
Model: SGH-A887
CountryCode: ATT
Factory SW: UCIJ1
UniqueNumber: 80110000257544
MemoryPhone: K5R2G1GACC(A887)S
IMEI: 35704403855674/9
Phone S/N: RU1Z195597
Build: SBAM6290A-KPVZL-1.2.0075_3S
Reading SysInfo... OK
Calculating... error ================> YOU WILL GET ERROR, relax...
Searching SysInfo... OK
Calculating codes... OK (time - 00:00:13)
Freeze code: 06927139
NET lock: #7465625*638*28203693#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
Multi lock: #7465625*685*12369874#
SIM lock: #7465625*746*12369874#
For check lock status: *#7465625#
Done with Samsung 3G tool ver 9.3 ===> use this soft
br, VODAFONES
The Following User Says Thank You to VODAFONES For This Useful Post:
Old 02-04-2011, 09:17   #11 (permalink)
VODAFONES's Avatar
Member: 747968
Sonork: 100.1621353
Thanks Meter: 444
UNLOCK SAMSUNG SOFTBANK 920SC
1. Power on phone.
2. Connect RJ45 (COM) cable.
3. Choise unlock method: Unlock or Relock.
4. Choise port of RJ45 connector in port settings
5. Press Unlock SP button.
6. Flash media and network patch firmware.
1. Switch phone to flash mode (*+#).
2. Connect USB cable and choise correct fw files.
3. Press update firmware button.
FLASH WITH : 920SCHF3_camera_and_media_patch.crp
Model: SGH-V920
CountryCode: SBM
Factory SW: 920SCGL8
UniqueNumber: 70540000123873
MemoryPhone: KBE00S00AB(V920)
IMEI: 35166202030668/6
Phone S/N: R3YQ108220
Build: M6280A-KLRZ-4.0.5080
Reading file... OK
Model: 920SC
Version: 920SCHF3
Info: camera and media patch
Searching Samsung USB Flash interface... not found
Reading file... OK
Model: 920SC
Version: 920SCHF3
Reading file... OK
Model: 920SC
Version: 920SCHF3
Searching Samsung USB Flash interface... detected (COM98)
Sending file 1 of 4... sended
Sending file 2 of 4... sended
Sending file 3 of 4... sended
Sending last file... sended
Flashing done (time - 00:05:50)
br,
VODAFONES
Old 03-14-2012, 07:06   #12 (permalink)
Member: 1673143
Thanks Meter: 9
Samsung galaxy y S5360 android v2.3.6 unlock done
Samsung galaxy young s5360 android v2.3.6 unlock done step by step.
SMART provider.
Tools:
z3x box
Samsung tool v12.1
mini usb
Procedure:
how to root Samsung galaxy y android v2.3.6
*dowload update zip http://dl.xda-developers.com/attachd...8/8/update.zip
*copy and paste the update zip file to the root of the micro sd
scard. do not extract.
*rooting phone procedure/ insert micro sd card to phone.
press volume up,home and power button.
wait until phone turn into recovery mode then select apply update from sd card
using volume up or down button.
select update_2.zip
select reboot system now.
after rebooting unlock procedure:
open samsung tool v 12.1
select correct model
select correct com port
select read codes
and unlock.
while unlocking the phone superuser request pop up on the screen of the phone just select allow only.
wait until unlocking finish then turn off the phone,
turn on the phone with sim card input NCK codes wait till unlocking successful.
testing
The Following 5 Users Say Thank You to nicodamo14 For This Useful Post:
Old 05-24-2012, 21:34   #13 (permalink)
Member: 561932
Thanks Meter: 167
Note: not compatible security S7250 and S7250D
If you flash in S7250 patch apps from S7250D - after flash (imei not activ) and logs soft 1234567891234 - need after read code flash original apps S7250 and imei will be ok. And vice versa(flash in S7250D apps from S7250).
The Following 3 Users Say Thank You to alex999_ For This Useful Post:
Old 06-22-2012, 15:33   #14 (permalink)
Member: 1482377
Thanks Meter: 27
1 - Flash your S7250 with S7250D firmware from support (S7250DXXKK1_OXE) without bootfiles
2 - Flash your phone with apps_patch_S7250DXEKK1.bin from support
3 - Read codes you get NCK code (save them you will use it)
4 - You got bad IMEI, d'ont worry
5 - Reflash your S7250 with original firmware or this one (S7250XXKK1_S7250OXAKK1_DBT, from support),
if there is no FFS file use one of (S7250DXXKK1_OXE):FactoryFs_S7250D_Open_Europe_Com mon.ffs
6 - Enter your NCK code calculated on step 3
7 - Unlock Done, true IMEI
8 - D'ont forget THANKS
The Following 5 Users Say Thank You to Samir_dz For This Useful Post:
Old 04-05-2013, 05:56   #15 (permalink)
Member: 1904833
thanks bro for sharing d wonderful information.....
FAQ - LG Phones. Souhail Z3X-Team Products 9 10-31-2018 23:04
-== Total Samsung Tool 1.03 ==- A COMPLETE SOLUTION FOR NEW SAMSUNG PHONES SiRoYa Main Sales Section 0 03-12-2005 13:55
new support for samsung i series and samsung phone card gc 82 badil Twisterflasher 0 12-10-2004 15:15
Page generated in 0.59772 seconds with 9 queries
