Old 06-25-2013, 15:30   #46 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 416
Originally Posted by SHIJILFONOTLY View Post
samsung S6810P,S6810L Used Two Types Of Security Old And New
New Security Phone Cant Unlock Below 14.9 Software Version
OtherWise New Security Phone Go To Dead After The Unlock
Make Sure Using SOftware 14.9
How To Alive The Dead Phone
MUST USE Jtag No other Way to Repair this Phone
Thank You For The Understanding
It Means New Version Samsung_14.9 Can Unlock Both New And Old Security
With Out Any Hassle
Am I Right?
Old 06-25-2013, 21:36   #47 (permalink)
Member: 557956
Thanks Meter: 4
thanks for replying, I did not know and kill him, as I recover with jtag? and with that box as would be the procedure?
Old 07-27-2013, 07:03   #48 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,419
Samsung adroid phones while flashing show this error?
3
BAD FLASH FILE MAKE THIS PROBLEM
TRY TO USE OTHER FIRMWARE
Old 07-27-2013, 14:11   #49 (permalink)
Member: 351924
SAMSUNG GALAXY i9505 S4 READ CODE&UNLOCK WITH IN SECONDS
ENTER *#7284#
SELECT TO MODEM
ENTER *#9090#
SELECT DM UART 4th Option
Open z3x 3g Tool
Com Set To Z3X
Power On The Phone Connect UART Cable Then Unlock
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-05-2013, 23:44   #50 (permalink)
Member: 2017871
Hello there,
Thanks a lot for this tutorial.
My S3 fell on water and is now with the imei null/null and baseband unknown problem, do you believe this method can help me? I ordered a SIM/SD Tray replacement but I bet that wont solve my issue. If it is indeed a hardware issue, what should I look for when I open it up?
Thanks in advance for ur input.
Old 09-07-2013, 09:56   #51 (permalink)
Member: 351924
Originally Posted by Badelhas View Post
Hello there,
look this link
some details here
GT-I9100 Phone version Unknown Problem Repair Guide
Old 09-08-2013, 01:35   #52 (permalink)
Member: 2017871
look this link
some details here
Thanks for the answer but I dont understand what you mean...can you please explain?
Thanks
Old 09-15-2013, 18:58   #53 (permalink)
Member: 1545797
Sonork: 1596859
Thanks Meter: 84
bro i try this sloution mnay time but same error
with out battry set not concet
Selected model: S3572
Selected port: COM6 Z3X BOX Serial Port
Selected port speed: 921600
Reconnect battery and connect phone to USB cable
Phone detected
Opening device... OK
Checking device descriptions... error
Done with Samsung Tool v.14.9
Old 10-15-2013, 11:51   #54 (permalink)
Member: 351924
Checking Super user right... false
Rooting phone, please wait... error
So many user faced this error while unlock and repair imei etc...
problem root error
you must root the phone via vroot then try to unlock or repair
with z3x
VRoot 1.7.0 - 1-Click Root Method mostly All andriod phone not metter which brand
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 01-11-2014, 00:00   #55 (permalink)
Member: 1243102
Sonork: sly-tech
Pls I unlck s5230xxih1 and it hang on the logoo wat do I do
Old 03-07-2014, 08:00   #56 (permalink)
Member: 1978575
Exclamation after unlock dead
i have the same problem................
Old 07-15-2014, 13:54   #57 (permalink)
SAN INFOTECH's Avatar
Member: 484665
Sonork: 100.1578012
Thanks Meter: 156
SAMSUNG IMEI,NETWORK,INSERT SIM(FLIGHT MODE ONLY)NOT 100%SOFTWARE DEFECT
HOW TO CHECK PROBLEM HARDWARE OR SOFTWARE
1)POWER THE PHONE WITHOUT SIM CARD ENTER *#06#
IMEI SHOW
IMEI: 004999010640000
(SOLUTION)
1)ENABLE USB DEBUG MODE ALSO READ INSTRUCTION FROM SOFTWARE HELP
2)REBUILD IMEI WITH Z3X
2)IMEI SHOW LIKE THIS?
(SOLUTION)
2)REBUILD IMEI AND REPAIR EFS WITH Z3X
WHILE REBUILD IMEI GOT THIS ERROR?
NO MORE TRY IMEI REBUILDING AND EFS REPAIR WITH Z3X
TRY TO WRITE EFS WITH JTAG
RIFF JTAG - How to repair Samsung baseband and IMEI (2)
AFTER WRITE THE EFS IMEI COME TO THEN TRY TO FIX THE IMEI([email protected])
AFTER WRITE THE EFS FILE WITH JTAG IMEI STILL SAME NULL CONDITION NO NEED TO MORE TRY WITH SOFTWARE PROBLEM GO TO
HARDWARE
after this operation phone imei is ok but phone not show network when i was trying call phone show me data network not allow
1- network icon show me this 0
Old 11-29-2014, 11:03   #58 (permalink)
Member: 661195
Thanks Meter: 27
Phone detected
Dear,
please help me to unlock sm-g313ml Ace4 phone via z3x.this model not in list.only g313h and g313hz.
Old 11-06-2015, 16:00   #59 (permalink)
Member: 1306687
Sonork: ayman
Thanks Meter: 10
G531F e failed to mount /efs
Old 07-24-2017, 19:27   #60 (permalink)
Member: 2077031
Thanks Meter: 3
Question
Originally Posted by blang View Post
UNLOCKING PROCEDURE 805SC, 705SS, 707SC, 707SC2 SOFTBANK
1. Check phone battery. Must be Full.
2. Power on phone.
3. Connect RG45 part of cable to box.
4. Run QTool, choise 805sc and press unlock.
IMPORTANT: If after unlocking 805SC you got blink on lcd, reflash your phone.
in last soft update not have this model what model can select ?
FAQ - LG Phones. Souhail Z3X-Team Products 9 11-01-2018 00:04
-== Total Samsung Tool 1.03 ==- A COMPLETE SOLUTION FOR NEW SAMSUNG PHONES SiRoYa Main Sales Section 0 03-12-2005 14:55
new support for samsung i series and samsung phone card gc 82 badil Twisterflasher 0 12-10-2004 16:15
Page generated in 0.44030 seconds with 9 queries
