05-11-2016, 17:45 | #1 (permalink) | |
Moderator Join Date: Jan 2011 Location: Throne of GsmHosting
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | First N920C DRK , DMVT Repair Done 100% By Z3x Info About phone: Model: N920c Build: N920CXXU2BPBA Version: 6.0.1 Issue: DM-Verity verification failed Condition: Hanged on startup logo Pre Require: Recovery pack V1.2 From server (to save time while processing) Samsungtool pro 25.2 or above Enough batter to process Process (Read in software): 1: COnnect phone in download mode 2: go to repair tab in samsung tool pro 3: click Repair Drk 4: Software reboot your phone in recovery(power by z3x officials) ,Pic Attach below. 5: Wait untill your pc install drivers for ADB , If software fails to detect your phone in ADB , use power button to reboot system now(but once your computer finish the driver installation)0 then start it from step 1. Ps: Software will wait till 100% for Adb So if your drivers are installed then wait till software end to 100%. Log Of the Process: Quote:
Dashing Z3x Recovery: Working Phone: Purpose Of sharing this is to help others. Thanks | |
The Following 4 Users Say Thank You to Sitlay KING For This Useful Post: |
08-15-2016, 12:14 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Operation: Repair DRK Selected model: SM-N920C Software version: 26.4 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM11 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: N920CXXU2AOJ5 Platform: exynos7420 Boot serial: 05157df5dc3b8426 Product board: zenlte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.26.4 |
11-07-2016, 10:13 | #3 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2139591 Status: Offline Thanks Meter: 78 | Sir Flashed with same Firmware to N920c, but when I pressed Repair DRK, It always says, "Recovery is NOT SEANROID encording or something like that |
The Following User Says Thank You to afnanbangash For This Useful Post: |
02-03-2017, 07:34 | #8 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Nepal
Member: 1370803 Status: Offline Sonork: ma341032 Thanks Meter: 36 | Operation: Read Codes Selected model: SM-N920C Software version: 27.7 Searching Samsung modem... detected COM591 Reading phone info... Ok Model: SM-N920C AP version: N920CXXU3BPJ9 CSC version: N920COJV3BPJ3 CP version: N920CXXU3BPK1 Product code: SM-N920CZKAKSA Phone SN: RF8H411FL7D Unique number: 85B652414F583634 Reading IMEI... Ok IMEI: 358023071916332 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON333 HWID: 68 89 40 CD 77 04 00 00 00 00 00 00 00 00 00 00 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 79713174 NET lock: 02826971 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to ma341032 For This Useful Post: |
04-06-2017, 14:06 | #9 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | I can't repair DRK: Quote:
BR | |
04-06-2017, 14:07 | #10 (permalink) | |
BR | |
04-16-2017, 12:21 | #11 (permalink) |
Junior Member Join Date: Nov 2014 Location: dubai
Member: 2300001 Status: Offline Sonork: 100.1669864 Thanks Meter: 0 | i have the same problem with my phone n920c and i haven't z3x box only octopus.............. if i can do with this box plz tell me how to do this becoz i try to many firmware |
02-19-2018, 06:35 | #13 (permalink) |
Insane Poster Join Date: Dec 2010 Location: nepal
Member: 1471030 Status: Offline Thanks Meter: 37 | no need at all just reset frp with urt z3x or root your phone 1000% https://drive.google.com/open?id=1BC...662dEI9xQD6bQe if you need flash than TUR_N920CXXS3BQA9_N920COJV3BPJ3_N920CXXU3BQA1 search and flash with this file 6.0.1 |
The Following User Says Thank You to mobile_sujan01 For This Useful Post: |
03-06-2018, 18:46 | #14 (permalink) |
Freak Poster Join Date: Oct 2016 Location: SUDAN
Member: 2637339 Status: Offline Thanks Meter: 44 | not work in latest binary 4 Operation: Repair DRK Selected model: SM-N920C Software version: 30.8 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: N920CXXS4CRA1 Platform: exynos7420 Boot serial: 84314d45374d5241 Product board: zenlte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.30.8 |
