10-30-2012, 15:27 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1830467 Status: Offline Thanks Meter: 0 | Flash Samsung E2550 Help!!! I have to change the language of the firmware, connection cable called J750 that is the one that communicates with the phone and then crush of firmware, all with the latest Samsung Tools and appears this request: Selected model: E2550 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: E2550XXJG4 Phone CSC: E2550OXFJG3 Phone BT ADDR: FCA1-3E-09464B Phone IMEI: 35309304952069 Deactivated MSL - TRUE [FREZEE]: 88355900 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00000000 Read info - ok Elapsed time: 26 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2550 Selected com port: COM3 Selected speed port: 921600 Press "*" + "#" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- What de vo do? Which cable should I use when I asked * + #, I do not understand anything, I've tried everything. I hope you can help me. Thank you. |
10-30-2012, 15:31 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | hold * and # on your phone keybord while connecting it, just when it appears from tool. don't release keys, it should connect then send loaders then reconnect, after you can release both keys. |
10-30-2012, 18:18 | #10 (permalink) |
Member: 1830467 Status: Offline Thanks Meter: 0 | Nothing, E210 does not communicate with either, if I put it in Tat mode with J750 and try to get it to communicate later with E210 usb which also communicates the same, the problem is I'm having to activate absurd usb cable that does not exist. |
10-30-2012, 19:21 | #12 (permalink) |
Member: 1830467 Status: Offline Thanks Meter: 0 | Look, you got it wrong, absurd is that I can not do the flash with a cable that communicates, I did not misunderstand anything, I seek help because I know nothing about these things and I write with google translator because I'm Italian, so I put the words how can I together. |
10-30-2012, 19:34 | #14 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Ok, try to find an original samsung usb cable. I assume you start in business, you'll see you'll have to get stuff very often, and you can't work properly only with cables that are supplied with your box. When you have it, retry and post log in here. |
10-30-2012, 19:37 | #15 (permalink) |
Member: 1830467 Status: Offline Thanks Meter: 0 | The original cable E2550 I have, and I tried to connect with him by putting it into the box, but does not communicate, only managed to communicate only the J750 cable but leaves the problem that I wrote before. |
