10-18-2017, 20:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Gela
Member: 293758 Status: Offline Thanks Meter: 39 | Flash samsung s7 edge not possible restart phone |
10-18-2017, 21:08 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | If you are trying root or whatever you want to do on 7.0, installing twrp and and sliding will trigger dm-verity, and if you do not do a wipe phone will not boot... so follow these steps it will boot: This is for G935 Exynos Model: (SM-G935F, SM-G935FD, SM-G935X, SM-G935W8) WARNING: This will wipe your device, backup your data Put your phone into download mode and run Odin Untick auto-reboot... Flash TWRP Recovery: twrp-3.1.1-0-hero2lte.img.tar After flashing TWRP, boot into recovery.. From wipe select Format Data... type yes and after wipe go back to Main Menu and select reboot, reboot to recovery.. After reboot browse to install and flash Supersu 2.82 (you can use SD-Card or OTG cable): SuperSU-v2.82-201705271822.zip Reboot your device... this will take up to 5 minutes PS: Wipe data is a MUST because when you swipe TWRP it will trigger dm-verity, and if you don't wipe you will be unable to boot |
