01-23-2016, 08:47 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Online Sonork: 100.1640471 Thanks Meter: 256 | Samsung Grand prime SM-G531H SIM Network unlock PIN done by z3x box pro Sodia arabia sim network unlock PINdone 100% done by me UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G361H Software version: 24.1 Searching Samsung modem... detected COM283 Reading phone info... OK Model: SM-G531H Version: G531HXXU0AOH8/G531HOJV0AOH2/G531HXXU0AOH7/G531HXXU0AOH8 Product code: SM-G531HZDDKSA Phone S/N: R51G91HEW3X Imei: 354621070576850 Unique number: C5K1372B696FE82 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:35) Freeze code: 19647147 NET lock: 09295728 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.1 |
01-23-2016, 13:54 | #2 (permalink) |
Member: 844312 Status: Online Sonork: 100.1640471 Thanks Meter: 256 | next or handaset sim network unlock PIN Sm-G531H +FRP lock ok done faild z3x box FRP lock Removed Faild but Octopus Removed succefull frp lock . UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G531H Software version: 24.1 Searching Samsung modem... detected COM284 Reading phone info... OK Model: SM-G531H Version: G531HXXU0AOK2/G531HOJV0AOK1/G531HXXU0AOK2/G531HXXU0AOK2 Product code: SM-G531HZDDKSA Phone S/N: R51G81W3HGF Imei: 354204072455975 Unique number: CQN000DB39BDC72 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:32) Freeze code: 15280317 NET lock: 57524242 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.1 |
The Following User Says Thank You to sohidul For This Useful Post: |
12-23-2017, 14:39 | #3 (permalink) |
Insane Poster Join Date: Jul 2017 Location: Bangladesh Age: 28
Member: 2740295 Status: Offline Thanks Meter: 33 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G531H/DS Software version: 30.1 Searching Samsung modem... detected COM38 Reading phone info... OK Model: SM-G531H Version: G531HXXU0AOH5/G531HOJV0AOH2/G531HXXU0AOH4/G531HXXU0AOH5 Product code: SM-G531HZWDKSA Phone SN: R51G90BVSRW IMEI: 3542xxxxxxxxxxxxxxx Unique number: C5K1345A2364082 Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.1 |
