12-16-2015, 13:48 | #1 (permalink) |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | FRP G925T Not Working Searching Samsung USB Flash Interface... detected COM38 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error any solution for this?? |
12-16-2015, 15:57 | #2 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | Quote:
01-11-2016, 00:28 | #9 (permalink) |
Freak Poster Join Date: Sep 2007 Location: France
Member: 589304 Status: Offline Thanks Meter: 74 | hy freind to fix this problem flash this boot to your phone with odin and do remove frp with z3x box G925T-Sboot |
08-15-2016, 18:00 | #10 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2412218 Status: Offline Thanks Meter: 0 | G925T Z3X FRP error solved!!! THANK YOU THANK YOU THANK YOU! Hi friend, just wanted to thank your for you input in this threat. I downloaded the sboot file, flashed it to the phone, causing it to go into a boot loop but allowing me to reset FRP. Afterward, just to fix the boot loop, i was able to re-install its original firmware on it. THANK YOU! |
