05-22-2018, 03:35 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
05-22-2018, 12:13 | #5 (permalink) | |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | Quote:
it's not going there | |
05-22-2018, 14:57 | #6 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | I tried to change the firmware to zcu but it made a mistake FLASH INSTRUÇÕES: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G9600 Software version: 31.5.1 Analisando arquivo... OK Total file size: 0x17A5BABF9 (6053 Mb) Searching USB Flash interface... COM4 detected Configurando conexão... OK Set PIT file... OK Reading PIT from phone... OK Enviando abl.elf.lz4... error tempo Esgotado Done with Samsung Tool PRO v.31.5.1 |
