02-10-2017, 13:35 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Flash with Combination file like these: G935F COMBINATION FA60 G935FXXU1APE3 FACTORY REV00 user mid noship.rar G935F COMBINATION FA60 G935FXXU1APF2 FACTORY REV00 user mid noship.rar G935F COMBINATION FA60 G935FXXU1APG1 FACTORY REV00 user mid noship.rar |
02-10-2017, 15:19 | #5 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Rome
Member: 2282676 Status: Offline Thanks Meter: 14 | solved but i have problem "baseband unknown" serial exist but don't have IMEI REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1BPLB CSC version: G935FITV1BPJ1 CSC country code: ITALY CSC sales code: ITV HW version: Phone SN: RF8H327G0EF Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 Last edited by MoRpHeUsHaCk; 02-10-2017 at 15:29. |
02-11-2017, 13:20 | #9 (permalink) |
Member: 2282676 Status: Offline Thanks Meter: 14 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FWIN1APE1 CSC country code: ITALY CSC sales code: WIN HW version: Phone SN: RF8H327G0EF Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 |
02-11-2017, 16:10 | #10 (permalink) | |
Member: 2282676 Status: Offline Thanks Meter: 14 | Quote:
2) factory data and wipe cache 3) reboot 4) https://www.youtube.com/watch?v=euVFV8NPb3c&t=299s 100% frp off | |
