Old 02-16-2017, 01:04   #31 (permalink)
Member: 2500571
Sonork: 100.1676652
Thanks Meter: 16
Did not work "s6(G920T)" write file success but still FRP ON?
<ID:0/018> Added!!
<ID:0/018> Odin engine v(ID:3.1203)..
<ID:0/018> File analysis..
<ID:0/018> SetupConnection..
<ID:0/018> Initialzation..
<ID:0/018> Get PIT for mapping..
<ID:0/018> Firmware update start..
<ID:0/018> SingleDownload.
<ID:0/018> userdata.img
<ID:0/018> RQT_CLOSE !!
<ID:0/018> RES OK !!
<ID:0/018> Removed!!
<ID:0/018> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
Old 02-16-2017, 06:32   #32 (permalink)
Member: 2248104
Thanks Meter: 4
hey its not work with 2016 2017 only 2015 i try before
Old 02-16-2017, 09:04   #33 (permalink)
Member: 1794445
Thanks Meter: 9
i tried to g920f it is work for me
after flash on odin
just do fatory reset on settings
Old 02-16-2017, 10:02   #34 (permalink)
Member: 2683974
Sm-j700f exynos frp cleared in second,...great !!!
Old 02-16-2017, 10:05   #35 (permalink)
Member: 2001510
Thanks Meter: 14
what is recommended .tar or .tar.md5 flashing
Old 02-18-2017, 08:53   #36 (permalink)
Member: 464619
Thanks Meter: 32
<ID:0/006> Added!!
<ID:0/006> Odin engine v(ID:3.1101)..
<ID:0/006> File analysis..
<ID:0/006> SetupConnection..
<ID:0/006> Initialzation..
<ID:0/006> Get PIT for mapping..
<ID:0/006> Firmware update start..
<ID:0/006> SingleDownload.
<ID:0/006> userdata.img
<ID:0/006> NAND Write Start!!
<ID:0/006> FAIL!
<ID:0/006>
<ID:0/006> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1
Old 02-18-2017, 22:42   #37 (permalink)
Member: 2289718
This will not work with Canadian models, s7, s7 edge, etc (*W8)
FRP prevents custom binary.
Old 02-19-2017, 00:18   #38 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 665
<ID:0/018> Added!!
You need to do a factory reset.
Old 02-19-2017, 00:24   #39 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 930
no work even do facotry rest via this method
Old 02-19-2017, 02:23   #40 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 665
So this method is very limited to only certain models. :-/
Old 02-19-2017, 02:44   #41 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 930
right i test it work on old build like 5.1.1
Old 02-19-2017, 03:16   #42 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 665
But the title says "FRP remove 2017 Exynos & Qualcomm CPU's SAMSAUNG". Maybe they need to change the title. :-/
Old 03-09-2017, 20:02   #43 (permalink)
Member: 1662358
Thanks Meter: 29
Solved! I reflashed the firmware and flashed the hidden.img separately in Odin and success!
Old 03-09-2017, 23:04   #44 (permalink)
Member: 2690731
Thanks Meter: 5
Of course it won't work on Qualcomm devices, if it gives you unsupported dev type, that's probably because you're flashing the wrong userdata lol
Thanks Z3X for not encrypting your files!! Lmao!!
Good stuff y'all lol
Old 03-12-2017, 17:34   #45 (permalink)
Member: 2683086
Smile Samsung sm-j320az frp done!!!
Amazing
sm-j320az done
odin 3.12
reset frp very easy!!!
Thanks!!!
The Following User Says Thank You to IMPORT&EXPORT For This Useful Post:
Page generated in 0.36860 seconds with 7 queries
