09-11-2017, 20:31 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | G-955f not unlock UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G955F Software version: 29.2 Searching Samsung modem... detected COM154 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQDG CSC version: G955FUWE1AQDG CP version: G955FXXU1AQDG Product code: CWW Phone SN: XXXXXXX2L1T Unique number: CE041714XXXXXX210C Reading IMEI... OK IMEI: 358792XXXXXX960 Reading SN... OK Phone SN: XXXXXXA2L1 Enter MSL: 23242D570F293148430XXXXXXXXXX145 Bypass MSL... OK Unlocking... error Done with Samsung Tool PRO v.29.2 |
09-12-2017, 00:56 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
You have to read forum before you doing job. | |
The Following User Says Thank You to blang For This Useful Post: |
09-12-2017, 01:09 | #3 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Mr. Blang is right, Knox=1 cannot unlock. However to save time and headache especially for beginners, maybe you could stop the process during phone info read if the knox flag=1 or Product code: xxx is not on the server supported list. Just a suggestion, of course you do whatever you want. | |
09-15-2017, 06:53 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | There is no point to do that because you allready payed for the code. Yes, it will short the time lost on forum... but u stil loose those money. Br |
The Following User Says Thank You to maremestera For This Useful Post: |
09-18-2017, 15:48 | #8 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Romania Age: 48
Member: 194546 Status: Offline Thanks Meter: 4 | 02.07.2017 Blang tell us: 1 success code reading for listed above models (new qualcomm based models, which can be unlocked at this moment by msl 22usd) - cost 5 z3x credits (around usd.) Why says that, because i pay 60usd for nothing. Please refund my money. |
10-01-2017, 21:07 | #9 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2326162 Status: Offline Thanks Meter: 2 | [ 01/10/2017 18:02:00 ] Searching Samsung modem... detected COM17 [ 01/10/2017 18:02:00 ] Reading phone info... OK [ 01/10/2017 18:02:00 ] Model: SM-G955F [ 01/10/2017 18:02:00 ] AP version: G955FXXU1AQDD [ 01/10/2017 18:02:00 ] CSC version: G955FXSA1AQDD [ 01/10/2017 18:02:00 ] CP version: G955FXXU1AQDD [ 01/10/2017 18:02:00 ] Product code: XSA [ 01/10/2017 18:02:00 ] Phone SN: R58J52DP6SK [ 01/10/2017 18:02:00 ] Unique number: CE0417143871B03D0C [ 01/10/2017 18:02:00 ] Reading IMEI... OK [ 01/10/2017 18:02:00 ] IMEI: 358792085514693 [ 01/10/2017 18:02:00 ] Reading SN... OK [ 01/10/2017 18:02:00 ] Phone SN: R58J52DP6S [ 01/10/2017 18:02:00 ] Enter MSL: 4202604F025A2C522926153A21545B01 [ 01/10/2017 18:02:00 ] Bypass MSL... error (2) |
10-02-2017, 11:29 | #11 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Msl code in wrong or knox tripped Quote:
