02-08-2015, 14:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | G313HU Restart problem After Selecting wrong model I selected model G313H |
02-08-2015, 15:11 | #3 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,527 | http://forum.gsmhosting.com/vbb/f453...rters-1139639/ so hard read this?? 3. Thread BODY should contain full description of problem: --- important information wanted from user for get any simple answer --- - phone models, - status of phone before any job with phone, - phone firmware, - backups *.tar better 1st one, - all logs of each job with phone, - logs of job of last actual version of z3x sw for such models. ---- without such information in 90% case your post will be without any answer --- |
The Following 3 Users Say Thank You to blang For This Useful Post: |
02-10-2015, 06:55 | #4 (permalink) | |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Quote:
here is the repair logs -------------------------- 8-2-2015_14-45-33 -------------------------- Selected model: SM-G313H Selected port: COM1 Communications Port Selected port speed: 115200 Waiting ADB device... Operation aborted Done with Samsung Tool v.18.3 Selected model: SM-G313H Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... Operation aborted Done with Samsung Tool v.18.3 Selected model: SM-G313H Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: SM-G313HU Android version: 4.4.2 Product code: SM-G313HRWHINS Phone version: G313HUDDU0ANG6 PDA version: G313HUXXU0ANGJ CSC version: G313HUODD0ANG4 IMEI: 355370061394118 Phone S/N: RZ1F829KX4Z Checking Super user right... true Detecting NV partitions... not found Loading NV partitions from database... OK Repairing network... error 1 Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool v.18.3 Here is the flashing logs -------------------------- 8-2-2015_17-27-12 -------------------------- Selected model: SM-G313HU Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x3BA8E294 Searching USB Flash Interface... detected COM3 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\SM-G313HU_8-2-2015_17-29-21.pit Sending sboot.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending system.img... OK Sending hidden.img... OK Sending BcmBoot.img... OK Sending param.lfs... OK Flashing done (time - 00:02:57) Done with Samsung Tool v.18.8 | |
03-30-2015, 16:32 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | ur problem solved or not Quote:
but canot solved | |
12-05-2015, 18:37 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 238 | Hello and also I have this phone with only logo pb have flash diferents file but results same.Cant repaiar it.Is there anybody that know how can I repaiar this phone. FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G316HU Software version: 23.5 File analysis... OK Total file size: 0x3F9B72A0 (1017 Mb) Searching USB Flash Interface... detected COM21 Setup connection... OK Reading PIT from phone... OK Sending BcmBoot.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:25) Done with Samsung Tool PRO v.23.5 Last edited by TUN10; 12-05-2015 at 18:45. |
07-11-2018, 12:46 | #9 (permalink) |
Insane Poster Join Date: Sep 2010 Location: mumbai Age: 39
Member: 1387849 Status: Offline Sonork: 100.1623264 Thanks Meter: 15 | samsung G313H ace NXT phone restarting problem tryed to flash but error FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G313H Software version: 29.5 File analysis... OK Total file size: 0x3E2B7ACC (994 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending spl.img... error Done with Samsung Tool PRO v.29.5 can any one solve this plz Thanks |
