g360h checking pit partition after flash combination files hi mr.blang how to fix this https://s22.postimg.org/my7613igx/20161130_161631.jpg after i flash the combination files on support.. the phone not boot on normal i try to flash different firmware still the same |
before the problem of the phone null imei and no service |
pls need help mr.blang |
up................................... |
G360H Check pit partition after falsh Samsung G360H after flash with combination file handset showing pit partition failure. The first handset condition is damaged EFS so when try to write EFS handset goes to boot loop then try flash with different firmware but condition still continue. Then try to flash combination it's change condition PIT partition failure. I'm try flash with different type of firmware. so please help me to fix this problem.... I'm waiting for your helping hand........ |
me also having this issue .can any one help plz |
https://www.4shared.com/get/C4SffnKF...cksum_Off.html good luck |
G360h nothing ur file................................. |
use 4 file with pit. file |
G360H Check pit partition failed Solved Easy Jtag 100% Tested Me |
