Old 11-30-2016, 09:34   #1 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 63
g360h checking pit partition after flash combination files
hi mr.blang how to fix this
after i flash the combination files on support..
the phone not boot on normal i try to flash different firmware still the same
Old 11-30-2016, 09:37   #2 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 63
before the problem of the phone null imei and no service
Old 11-30-2016, 13:21   #3 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 63
pls need help mr.blang
Old 12-01-2016, 08:58   #4 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 63
up...................................
Old 01-13-2017, 05:49   #5 (permalink)
Member: 2170791
Thanks Meter: 37
G360H Check pit partition after falsh
Samsung G360H after flash with combination file handset showing pit partition failure. The first handset condition is damaged EFS so when try to write EFS handset goes to boot loop then try flash with different firmware but condition still continue. Then try to flash combination it's change condition PIT partition failure. I'm try flash with different type of firmware. so please help me to fix this problem....
I'm waiting for your helping hand........
Old 02-28-2017, 15:20   #6 (permalink)
Member: 2536451
me also having this issue .can any one help plz
Old 03-01-2017, 06:52   #7 (permalink)
sakisager's Avatar
Member: 149804
Thanks Meter: 94
use this file as boot and get worked again
https://www.4shared.com/get/C4SffnKF...cksum_Off.html
good luck
Old 03-23-2017, 02:49   #8 (permalink)
Member: 1419304
Thanks Meter: 3
G360h
nothing ur file.................................
Old 03-23-2017, 02:53   #9 (permalink)
-gayang-'s Avatar
Member: 2041408
Thanks Meter: 38
use 4 file with pit. file
Old 06-23-2017, 09:12   #10 (permalink)
Member: 2653615
Sonork: 100.1675715
Thanks Meter: 15
G360H Check pit partition failed Solved
Easy Jtag 100% Tested Me
Page generated in 0.28131 seconds with 7 queries
