10-03-2017, 12:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Majuro, Marshall Islands
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | G360T FRP Removed With G361H 1. Boot into Recovery Mode 2. Do a Factory Reset 3. Boot into Download Mode 4. Select Model SM-G361H 5. Select FRP/React/EE Note: Wifi is turned off at this stage so I didn't turn it on. Good Luck! Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.3.1 Searching Samsung USB Flash interface... COM4 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.3.1 |
The Following 6 Users Say Thank You to Jabbacks For This Useful Post: |
10-16-2017, 15:26 | #2 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | Thanks just did one with the same process. UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.5 Searching Samsung USB Flash interface... COM4 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.5 |
04-20-2018, 19:01 | #3 (permalink) |
Freak Poster Join Date: Dec 2008 Location: SKN Caribbean Age: 41
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | It works thanks brother UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 31.2 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.31.2 |
09-08-2018, 15:47 | #4 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Code: Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 33.7 Searching Samsung USB Flash interface... COM16 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.33.7 |
09-08-2018, 18:47 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
