11-28-2015, 04:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: NIGERIA
Member: 479049 Status: Offline Thanks Meter: 41 | G360t GIVES ERROR WHEN Reset FRP/React/EE Selected model: SM-G360T Software version: 23.4 Searching Samsung USB Flash Interface... detected COM83 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.23.4 |
12-02-2015, 09:37 | #5 (permalink) |
Member: 479049 Status: Offline Thanks Meter: 41 | Operation: Reset FRP/React/EE Selected model: SM-G360T Software version: 23.5 Searching Samsung USB Flash Interface... detected COM83 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.23.5 |
02-28-2017, 00:40 | #11 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | I try and not result. Code: Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: SM-G360P To put SM-G360P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.4.8 Software version. |
05-19-2017, 20:11 | #15 (permalink) |
Major Poster Join Date: Jan 2014
Member: 2114980 Status: Offline Thanks Meter: 9 | Hey I had the same issue and this is what worked for me. 1. I flashed the phone to "G360T1UVU1AOFA" which is a metropcs ROM, using Z3X. 2. Removed the FRP using SM-G360p on Octopus 3. Flashed back to "G360TUVS2AQA2" which is a Tmobile ROM, using Z3X. Hope this helps!! |
