01-09-2017, 08:04 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1935080 Status: Offline Thanks Meter: 0 | SM-G361F frp not supported I'm trying to unlock frp of samsung sm-G361f but : Operation: Reset FRP/React/EE Selected model: SM-G361F Software version: 27.7 Searching Samsung USB Flash interface... COM6 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... not supported Reset done Done with Samsung Tool PRO v.27.7 Can someone could help me ? Thanks |
01-09-2017, 08:23 | #5 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
select g920f in z3x and click on reset reactivation lock if anyone like my post press thanks button | |
The Following 5 Users Say Thank You to Asad ali khan For This Useful Post: |
01-09-2017, 09:03 | #8 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | try one of those ROM Quote:
OR THIS "G361FXXU1AOF9_BTU1AOF2" | |
01-09-2017, 09:10 | #9 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1087456 Status: Offline Thanks Meter: 39 | Quote:
The Following 2 Users Say Thank You to mijanur_017 For This Useful Post: |
01-09-2017, 21:36 | #12 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Poland Age: 44
Member: 87364 Status: Offline Thanks Meter: 63 | Operation: Reset FRP/React/EE Selected model: SM-G361F Software version: 27.7 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... not supported Reset done Done with Samsung Tool PRO v.27.7 but still FRP LOCK |
01-09-2017, 22:13 | #13 (permalink) |
Member: 87364 Status: Offline Thanks Meter: 63 | Problem soloved- use G531F: Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 27.7 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.7 FRP cleared |
The Following 38 Users Say Thank You to rgsm For This Useful Post: |
01-12-2017, 18:02 | #14 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Negotino
Member: 6517 Status: Offline Thanks Meter: 20 | Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 27.7 Searching Samsung USB Flash interface... COM18 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G531F" "Erasing EE lock error" - Ïîøóê Google Done with Samsung Tool PRO v.27.7 |
02-09-2017, 09:10 | #15 (permalink) |
Freak Poster Join Date: Nov 2009 Location: pitesti-romania
Member: 1171991 Status: Offline Sonork: cristy81y Thanks Meter: 3 | Insane Poster Join Date: Sep 2004 Age: 37 Posts: 94 Member: 80698 Status: Offline Thanks Meter: 7 Well the bug is on the software itself I downloaded ver 26.9 and it worked here is the log UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G361F Software version: 26.9 Searching Samsung USB Flash interface... COM12 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 |
The Following User Says Thank You to cristy81y For This Useful Post: |
