02-16-2017, 12:42 | #16 (permalink) | |
Freak Poster Join Date: Jun 2002
Member: 13345 Status: Offline Thanks Meter: 16 | Quote:
The Following 4 Users Say Thank You to Richie-40 For This Useful Post: |
04-30-2017, 19:52 | #20 (permalink) |
No Life Poster Join Date: Nov 2006 Location: algeria
Member: 395094 Status: Offline Thanks Meter: 58 | Problem soloved- use G531F: Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 27.7 Searching Samsung USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.7 FRP cleared |
The Following User Says Thank You to farouk842000 For This Useful Post: |
05-29-2017, 13:57 | #21 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | DONE BY SELECTING G531F ! Why not repair this bug ?! Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 28.1 Searching Samsung USB Flash interface... COM180 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.28.1 |
10-08-2017, 16:45 | #22 (permalink) |
Freak Poster Join Date: Sep 2004 Location: KHENIFRA MOROCCO
Member: 84034 Status: Offline Thanks Meter: 78 | G361F Reset FRP Operation: Reset FRP/React/EE Selected model: SM-G361H/DS ....................................... Software version: 29.4 Searching Samsung USB Flash interface... COM13 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.4 |
10-14-2017, 12:59 | #23 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 29.5 Searching Samsung USB Flash interface... COM179 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.29.5 |
10-24-2017, 15:55 | #24 (permalink) |
Junior Member Join Date: Jun 2008 Location: Poland BYDGOSZCZ
Member: 796368 Status: Offline Thanks Meter: 2 | first flash phone full flash (for example G361FXXU1AOF9_BTU1AOF2 5 files flash), then select g531f and use option Reset FRP/React/EE, its works good. |
The Following User Says Thank You to karollew For This Useful Post: |
11-18-2017, 19:09 | #25 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Unknown...
Member: 2688744 Status: Offline Thanks Meter: 166 | select model g531f tested 100% : UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 29.2 Searching Samsung USB Flash interface... COM33 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.2 |
11-26-2017, 18:40 | #26 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2535794 Status: Offline Thanks Meter: 0 | 100% worked for me with sw ver 27.9 Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 27.9 Searching Samsung USB Flash interface... COM7 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.9 |
06-16-2018, 07:34 | #27 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 858854 Status: Offline Thanks Meter: 109 | After change model G531F problem solved... Thanx for all... Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 32.7 Searching Samsung USB Flash interface... COM7 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.32.7 |
08-05-2018, 21:11 | #29 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: morrocco
Member: 345974 Status: Offline Thanks Meter: 23 | Quote:
Setup connection... OK Reading PIT from phone... OK Searching FRP lock... not supported Reset done Done with Samsung Tool PRO v.33.5 | |
08-05-2018, 21:18 | #30 (permalink) | |
Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.33.5 | |
