03-03-2016, 15:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | G361f not unlock ! i flashed it with a rooted file from support like i did with others, but this one, can't be unlocked. Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G361F Software version: 24.5 Waiting ADB device... OK Reading phone info... Model: SM-G361F Android version: 5.1.1 Product code: SM-G361FHAAXEF Phone version: G361FXXU1AOJ1 PDA version: G361FXXU1AOG1 CSC version: CSC country code: CSC sales code: HW version: MP 0.100 Phone S/N: RV8GB1NKBTB Modem board: RF cal date: 20151117 IMEI: Checking Super user right... false This model not supported for auto root Done with Samsung Tool PRO v.24.5 |
03-03-2016, 17:39 | #4 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | my probleme solved, just start superuser manuly in phone menu. Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G361F Software version: 24.5 Waiting ADB device... OK Reading phone info... Model: SM-G361F Android version: 5.1.1 Product code: SM-G361FHAAXEF Phone version: G361FXXU1AOJ1 PDA version: G361FXXU1AOG1 CSC version: CSC country code: CSC sales code: HW version: MP 0.100 Phone S/N: RV8GB1NKBTB Modem board: RF cal date: 20151117 IMEI: Checking Super user right... true Reading nv data... OK Analysing SEC file... OK Initialization AT RIL... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.5 thanks. |
The Following User Says Thank You to .:bono:. For This Useful Post: |
