12-22-2015, 11:44 | #17 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 53
Member: 121974 Status: Offline Thanks Meter: 87 | sm-g530a unlock select SM-G530H Operation: Unlock Selected model: SM-G530H Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 23.8 Reading phone info... Reading IMEI... OK IMEI: 35xxxxxxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.8 |
The Following User Says Thank You to ramcellular For This Useful Post: |
12-27-2015, 05:04 | #18 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1081345 Status: Offline Thanks Meter: 2 | danger.gsm, I want to publicly thank. I listened to the forums, release another model and remained stuck. the phone is not mine, I'm liberardor, I was desperate. in other forums with a high cost. chimera brings it, but the day before I left without a license. try lowering the chimera and soft with no accepted standard. brother, thank you, if you believe in ***, I send blessings, you brought me trouble. working at 100% and released. |
12-27-2015, 05:07 | #19 (permalink) | |
Member: 1081345 Status: Offline Thanks Meter: 2 | Quote:
The Following User Says Thank You to efrains94 For This Useful Post: |
12-27-2015, 07:50 | #20 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Here is my complete guide that has taken me a week of headaches. I will explain how to route, unlock, bricking and unbrick the Samsung Galaxy AT & T Prime SM-G530A. Straight to the point Root first with KingRoot apk v4.62 (do not restart the device until I told). Install Flashify, now with flashify install the Stock Kernel (NOW YOU CAN REBOOT). Use Samsung octopus v2.1.4 or v2.1.5 software and select the model SM-G530FZ, search Android / EFS Manager tab and click in ENABLE DIAG, now Main tab and then on Unlock. Ready, and our device will be rooted and unlocked. It is easy when you read this HUH? Now I put all I've had to go to if any of you have the same problem. 1st -) If you restart after the rooting proccess and the device runs in kernel error, Flash the Stock Kernel with Odin The 2nd -) Whoever restart after rooting or unlock and recovery device made by Samsung Kies variant restore the model SM-G530AZ, you'll lost IMEI. Have to restore the newly saved security located in the Dir C: \ Program Files (x86) \ Octoplus \ Octoplus_Samsung (ASEC extention file, if one does not have that extention Security rename it EXP G530A-SM-13-12-2015_08-34-20 -> Security-SM G530A-13-12-2015_08-34-20.asec) and ready, if you still fail to repair the IMEI must install the original ROM from here. ROM must be 4 files recovery because it is the one with the PIT necessary for proper installation that is in the CSC_ATT_G530AATT4AOI7_CL828509_QB6433914_REV00_use r_low_ship_MULTI_CERT.tar.md5 file, the solution posted by danger.gsm not do them because it is only AP_G530AUCU4AOI7_CL828509_QB6433914_REV00_user_low _ship_MULTI_CERT tar and would have to have 4 files repair. We follow and when downloading the ROM 4 files, look for the Odin 10.7 and we place the 4 files in their respective positions BL BL, AP in AP, CP in CP and CSC CSC course, now go to the Options tab and mark ( Auto Reboot) (Re-Partition) (F. Reset Time) (Nand Erase All) (Phone EFS Clear) (Phone Bootloader Update) and finally select Start. When you exit and restart the device longer have back their SM-G530A again without IMEI, now have to perform again the steps of writing security, then repeat the process of Root and Unlock detailing them at the beginning and go. If you need anything more than this device can notify me. give thanks if this helped you. bye. NVM QCN PIT |
The Following 4 Users Say Thank You to ernestico911 For This Useful Post: |
12-29-2015, 15:13 | #21 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1219775 Status: Offline Thanks Meter: 46 | Quote:
Can you please upload BL, CP,CSC to another virtual drive like 4shared or mediafire. Clangsm require vip permission in order to download those files | |
The Following 2 Users Say Thank You to Andosonson For This Useful Post: |
12-29-2015, 17:21 | #22 (permalink) | |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Quote:
Say Thanks if it works | |
01-01-2016, 00:05 | #25 (permalink) | |
Freak Poster Join Date: May 2013 Location: Haiti
Member: 1940476 Status: Offline Thanks Meter: 27 | Quote:
01-02-2016, 04:58 | #28 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2471533 Status: Offline Thanks Meter: 0 | just look for app root android without computer , follow the steps , select your device model For example: G530az, install it , run it and thats it . king root v4.8 works great on my samsung grand prime version 5.1.1 hope it helps you to root your phone |
01-02-2016, 16:48 | #29 (permalink) |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | The last king root available for now is 4.65 watabaraiz look in King Root Site |
