08-01-2015, 09:13 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Moldova
Member: 204684 Status: Offline Thanks Meter: 21 | G530FZ Root Please help! How can I root G530FZ with this version: G530FZXXU1AOF1. Older versions I rooted by iRoot... But this version I can't root using known by me methods. I don't want to downgrade to G530FZXXU1AOB5 'cause I don't know what result will be. Please, give advise! Thank you. |
08-25-2015, 17:56 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
So, I decided to Downgrade to (OA9) .. Right now i'm downloading (OA9) and i'll feedback later .. BR | |
08-25-2015, 19:04 | #3 (permalink) | |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Downgrade + Root + Unlock Success .. Kingroot used for Root .. Quote:
The Following User Says Thank You to MiRoOo For This Useful Post: |
01-23-2016, 04:08 | #5 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Ukraine
Member: 907534 Status: Offline Thanks Meter: 91 | http://forum.gsmhosting.com/vbb/f684.../#post11303677 Welcome to Octoplus/Octopus Box Samsung software version 2.1.8 ----------------------------------------------------------------------------------- To connect SCH-I545 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G530FZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: G530FZXXU1AOA2-20150115192355 _Android_4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put SM-G530FZ into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing QSEE section... QSEE section has been written successfully. Writing QHEE section... QHEE section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing sec section... sec section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530FZ Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM13 Mode: Normal Phone model: SM-G530FZ Firmware compiled date: Aug 10 2015 Firmware compiled time: 01:00:00 Firmware released date: Sep 16 2015 Firmware released time: 18:08:08 Phone IMEI: 351705-07-042885-8 SW version: MPSS.DPM.2.0.c5-00106-M8936FAAAANUZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G530FZ Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G530FZ Firmware compiled date: Thu Sep 17 14:21:41 KST 2015 PDA version: G530FZXXU1BOI2 CSC version: G530FZOXX1BOI1 SW version: G530FZXXU1BOI2 Phone SN: R58G40LPHFE Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. |
