12-24-2015, 11:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | g531h frp done Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531H/DS Software version: 23.9 Searching Samsung USB Flash Interface... detected COM17 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.23.9 |
The Following User Says Thank You to partycrasher131 For This Useful Post: |
06-18-2016, 17:54 | #2 (permalink) |
Crazy Poster Join Date: Apr 2007
Member: 490948 Status: Offline Thanks Meter: 8 | Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 25.7 Searching Samsung USB Flash Interface... detected COM13 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.7 |
08-16-2016, 13:42 | #4 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: GHANA Age: 28
Member: 2373688 Status: Offline Thanks Meter: 57 | Quote:
Flash with G531HDDU0AOH2_G531HODD0AOH2 or 2015 firmware then Reset again with Z3X. | |
02-27-2017, 11:59 | #6 (permalink) |
Junior Member Join Date: May 2015 Location: GUINEE_Gsm-Forward
Member: 2392236 Status: Offline Thanks Meter: 8 | FRP G531H USE NCKBox_Samsung_Module_v0.8.4 Device detected OK. Bypassing data, wait.... Bypass ok. Reading Data,wait.... Done Chipset: SPRD8735 Data Found, processing... Resetting FRP, wait.. FRP OFF... Done Now you can wipe phone to remove remaining data... Restarting Phone Restart Ok All Done Done. ---------------------- |
04-06-2017, 11:50 | #7 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: cavite
Member: 1215525 Status: Offline Thanks Meter: 25 | still have Quote:
please have a picture of your phone success | |
