06-13-2018, 04:41 | #1 (permalink) |
Junior Member Join Date: Feb 2015 Location: tanay, rizal
Member: 2353856 Status: Offline Sonork: 100.1645784 Thanks Meter: 2 | G532F march 1, 2017 direct read code done. no need root. UNLOCK INSTRUCTIONS: Direct unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To read security codes (without root permissions): 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes Selected model: SM-G532F Software version: 32.6 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 Phone version: G532FXXU1AQB3 Product code: SM-G532FZDDKSA CSC country code: KSA CSC sales code: KSA Phone SN: RV8J70PXWBD IMEI: 359614084712848 HW version: MP 0.300 RF cal date: 20170713 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM14 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:24) Freeze code: 53749516 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 46182606 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.32.6 |
