08-11-2018, 16:01 | #2 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | hello, to do the frp reset to the model sm-a320fl you can use the combination, note that the combination must be compatible with the stock firmware installed on the phone, if you want to put the phone in recovery mode and read the pda of the firmware you have installed and I can search for the combination |
The Following User Says Thank You to amleto90 For This Useful Post: |
08-11-2018, 19:54 | #5 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | you need to flash the combination using odin or z3x selecting the entry ap, done that, enter the factory binary settings selections from the menu and activate usb debbuging if you find the item oem unlock the active, done that you do the flash of 3 firmware files selecting the entries ap, bl, csc_home, I recommend not to use the single csc file but use the csc_home file |
