08-02-2017, 14:14 | #1 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1593435 Status: Offline Thanks Meter: 0 | g570f frp not off after write combination file and frp reset need help and mobile not flash with any latest version G570FDDU1AQE1_ODD1AQE1 always on factory binary HOW TO RECOVER??? PL HELP |
08-02-2017, 14:19 | #2 (permalink) |
Member: 1593435 Status: Offline Thanks Meter: 0 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G570F Software version: 29.0 File analysis... OK Total file size: 0xCE6394E0 (3302 Mb) Searching USB Flash interface... COM29 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending recovery.img... error timeout Done with Samsung Tool PRO v.29.0 Last edited by lovegsm007; 08-02-2017 at 14:25. Reason: MISTAK |
08-02-2017, 16:21 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: kerala india
Member: 952533 Status: Offline Sonork: 1001607366 Thanks Meter: 124 | flash 4 file without bootloader.after set flash chek recovery, then select correct file, after use recovery based compination, then remove frp in z3x, then flash latest file |
The Following User Says Thank You to anwar.welltech For This Useful Post: |
08-02-2017, 16:25 | #5 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2658812 Status: Offline Thanks Meter: 1 | 1st-full flash latest version file download by sam mobile then not flash full combination file only (boot .img & preloader) then use moto tool v 1.1 for frp remove |
The Following User Says Thank You to Manojgup94 For This Useful Post: |
08-02-2017, 16:38 | #7 (permalink) |
Member: 1593435 Status: Offline Thanks Meter: 0 | before flash combi recovary v G570FXXU1AQD2 and After combination file G570FDDU1AQE1 i flash with this combination file G570FDDU1AQE1 latest version file not write.....& binary block by frp |
