Old 11-30-2016, 13:24   #1 (permalink)
buntymurarka's Avatar
Member: 503911
Thanks Meter: 187
G610F Emergency Call After Repair Imei and Patch Certificate
Old 12-01-2016, 04:29   #2 (permalink)
Member: 503911
Thanks Meter: 187
Still after updating to 27.3 and after repair imei and patch certificate same
IMEI STATUS NG
Operation: Patch Certificate
Selected model: SM-G610F
Software version: 27.3
Waiting ADB device... Ok
Reading phone info...
Model: SM-G610F
Android version: 6.0.1
Product code: SM-G610FZKDINS
Phone version: G610FDDU1APJ6
PDA version: G610FDDU1APJ7
CSC version: G610FODD1APJ1
CSC country code: India
CSC sales code: INS
HW version: MP 0.300
Phone SN: RZ8H91MD0JW
Chip name: EXYNOS7870
Modem board: SHANNON315
RF cal date: 20160926
IMEI:
Checking Super user right... true
Reading NV data... Ok
Checking NV data... Ok
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Initialization zTool... Ok
Rebooting phone... Ok
Patching CERT check... done
Done with Samsung Tool PRO v.27.3
Old 12-01-2016, 04:56   #3 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 209
your imei status in NG, its need PASS for OK,
write another cert file, and it,ll be OK if write cert option is available
The Following User Says Thank You to .:D:. For This Useful Post:
Old 12-01-2016, 05:07   #4 (permalink)
Member: 503911
Thanks Meter: 187
i repair imei with new z3x update and patch certificate but still same
i dont have readed cert
Old 12-01-2016, 06:55   #5 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 209
unfortunately i have no set in my hands ,
and even not in octopus support,
Old 12-01-2016, 07:51   #6 (permalink)
Member: 2528453
Sonork: Gsm unlock
Thanks Meter: 60
Same problem after repair imei emergency call z3x team only unlocking working slution all fake update slove this bugs ......
Old 12-01-2016, 08:36   #7 (permalink)
Member: 1485377
Sonork: 100.1623194
Thanks Meter: 45
New Fake update Thanks
Old 12-01-2016, 14:36   #8 (permalink)
Member: 503911
Thanks Meter: 187
i request team to fix bugs in new updates asap
Old 12-01-2016, 14:36   #9 (permalink)
Member: 503911
Thanks Meter: 187
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Model: SM-G610F
CSC sales code: INS
IMEI:
Running zTool, please wait...
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data from phone... Ok
Calculating... Ok
HWID: D6 02 00 00 00 00 00 00 00 00 00 00 AE 8D 1A CF
Initialization AT RIL...
AT RIL stopped, restarting... Ok
Checking for compatible phone and cert
Phone KEY ID: 0542
Checking certificate file... error
Incorrect IMEI signature
Old 12-09-2016, 20:44   #10 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 539
Same problem with me
Old 12-11-2016, 09:31   #11 (permalink)
Member: 2564038
Sonork: 100.1674499
Thanks Meter: 132
G610F imei status NG Same here
Please Z3x Fix This Bug
Thanks
Old 12-11-2016, 11:13   #12 (permalink)
Member: 1808655
Thanks Meter: 26
NOT FAKE try other firmwARE YOU ARE MUST TRUe MODEM version firmware
Old 12-11-2016, 12:07   #13 (permalink)
K-B MOBILE's Avatar
Member: 2574306
Thanks Meter: 180
Not Fake I Have Repair it 100% Working with Full Signal..
Old 12-11-2016, 13:54   #14 (permalink)
omairlee01's Avatar
Member: 2068959
Thanks Meter: 160
J7 prime g610f 6.0.1 unlock solve w/o root
20mb image hosting
Old 04-05-2017, 19:37   #15 (permalink)
Member: 136882
Thanks Meter: 9
Hi All,
same problem here G610 repaired IMEI and patched cert.
Status both stacks: OK
After 1 day (without any update of firmware) status turned to NG.
How is this possible?
Thx in advance
Page generated in 0.41638 seconds with 7 queries
