05-22-2017, 16:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | G610F FRP done, but sill locked ? i flashed the conbination file from support, phone has enter adb mode, unlocked frp with z3x, hard reset after from menu and from recovery, flashed back with oficiel firmware, frp still locked ! how to fix it ? thanks |
05-22-2017, 17:11 | #2 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | here is log: Code: Operation: Reset FRP Selected model: SM-G610F Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDTMC Phone version: G610FDDU1AQC2 PDA version: FA60_G610FDDU1AQC2 CSC version: CSC country code: CSC sales code: HW version: MP 0.300 Phone SN: R28J13J923A Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-08-01 RF cal date: 20170125 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
05-22-2017, 20:52 | #5 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. Put the phone in download mode 2. Flash this combination factory COMBINATION_ODI_FA60_G610FXXU1API1_ODIFA60_G610FDD U1API1_CL9154841_QB10812653_REV00_user_mid_noship. tar.md5.rar 3. When the phone restart make sure that usb debugging is enabled 4. Conect the Phone to Z3X in NORMAL MODE 5. ADB ok 6. Do FRP 7. After restarting the phone, delete from the phone menu 8. Flash with original firmware and FRP:Off (Pass to descompress into the .rar) It says into the post. Pass to descompress: Click twice with the mouse with the left button and you will see the password to decompress. |
05-23-2017, 11:49 | #8 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
Code: Operation: Flash Selected model: SM-G610F Software version: 28.2 File analysis... Ok Total file size: 0x5096EC84 (1289 Mb) Searching USB Flash interface... COM23 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... error timeout Done with Samsung Tool PRO v.28.2 | |
The Following User Says Thank You to .:bono:. For This Useful Post: |
05-23-2017, 12:07 | #10 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | Code: <ID:0/023> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/023> Odin engine v(ID:3.1101).. <ID:0/023> File analysis.. <ID:0/023> SetupConnection.. <ID:0/023> Initialzation.. <ID:0/023> Set PIT file.. <ID:0/023> DO NOT TURN OFF TARGET!! <ID:0/023> FAIL! <ID:0/023> <ID:0/023> Re-Partition operation failed. <OSM> All threads completed. (succeed 0 / failed 1) also can't do it |
05-23-2017, 12:15 | #11 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First of all: 1. Are you using an original quality USB lead? 2. Are you connecting directly to the computer USB port and not through a USB hub? 3. Try another USB port on the PC. |
05-23-2017, 12:20 | #12 (permalink) | |
i can also flash original flash G610FDDU1APLB_OJV1APJ1_Arabic_6.0.1 without a probleme too, same cable, same pc same software. | |
05-23-2017, 13:35 | #13 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | same probleme with another combination file COMBINATION_ODD_FA60_G610FDDU1AQC1_ODDFA60_G610FDD U1AQC1_CL9139094_QB12743015_REV00_user_mid_noship. tar. frp not removed ! |
05-25-2017, 13:56 | #14 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | after trying some enable adb files, i managed to enable OEM in dev menu, then sucsseed to unlock the phone, with the help of z3x and unitool volcano, job done. frp : off br. |
