12-16-2016, 11:20 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: kathmandu
Member: 1915808 Status: Offline Sonork: 1656805:2042 Thanks Meter: 29 | g610f unlock problem 1 sept 2016 Searching Samsung modem... detected COM48 Reading phone info... Ok Model: SM-G610F AP version: G610FDDU1APHD CSC version: G610FOJV1APH5 CP version: G610FDDU1APH9 Product code: SM-G610FZDDKSA Phone SN: R28HA13RZGL Unique number: CAJ03EB27495093 Reading IMEI... Ok IMEI: 353116 (SIGN: OK) IMEI 2: 3591 (SIGN: OK) Checking hash file... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.5 |
12-20-2016, 12:49 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
for unlock - just root phone. | |
03-11-2017, 19:19 | #3 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Chandpur U.P.West India
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | Quote:
https://drive.google.com/file/d/0B_W...dEWWNMSUk/view don't forget to press thanx button | |
The Following 7 Users Say Thank You to farsi_007 For This Useful Post: |
03-14-2017, 00:18 | #4 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: Malawi
Member: 2330405 Status: Offline Sonork: 100.1661964 Thanks Meter: 37 | Quote:
03-14-2017, 19:55 | #6 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | Here is working link https://drive.google.com/file/d/0B_W...w?usp=drivesdk Don't forget to press thanx button |
The Following 11 Users Say Thank You to farsi_007 For This Useful Post: |
03-15-2017, 16:01 | #8 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: kasaragod, Kerala, India
Member: 1812419 Status: Offline Thanks Meter: 156 | Quote:
The Following User Says Thank You to aaditigerhill For This Useful Post: |
03-19-2017, 04:17 | #10 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1009132 Status: Offline Thanks Meter: 23 | i've tried to downgrade with this modem, but still error 0.... Searching Samsung modem... detected COM60 Reading phone info... Ok Model: SM-G610F AP version: G610FDDU1APLC CSC version: G610FOJV1APJ2 CP version: G610FDDU1APJ6 Product code: SM-G610FZDDKSA Phone SN: R28H934YJ8F Unique number: CAJ032D3AEC6E93 Reading IMEI... Ok IMEI: 353111082052745 (SIGN: OK) IMEI 2: 353112082052743 (SIGN: OK) Checking hash file... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.8 |
03-20-2017, 12:11 | #11 (permalink) | |
wait for update asap. | |
The Following User Says Thank You to blang For This Useful Post: |
06-19-2017, 22:23 | #12 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: chenai,india
Member: 883886 Status: Offline Sonork: 1664059 Thanks Meter: 111 | thanks Quote:
UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G610F Software version: 28.2 Searching Samsung modem... detected COM18 Reading phone info... Ok Model: SM-G610F AP version: G610FDDU1AQB1 CSC version: G610FODD1APL1 CP version: G610FDDU1APJ6 Product code: SM-G610FZDDINS Phone SN: RZ8J3***** Unique number: CAJ03541****** Reading IMEI... Ok IMEI: 357488******** (SIGN: OK) IMEI 2: 35748******* (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHAN***** HWID: A7 07 00 00 00 00 00 00 00 00 00 00 78 F3 59 2B Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 71936973 NET lock: 37913816 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.2 | |
The Following User Says Thank You to mransar For This Useful Post: |
07-06-2017, 09:46 | #13 (permalink) | |
Freak Poster Join Date: Mar 2008
Member: 737862 Status: Offline Thanks Meter: 41 | sm-g610f unlock done Quote:
thanks sir working 100%%%%%%%%%%%%%%%% | |
The Following 3 Users Say Thank You to shahid74 For This Useful Post: |
11-10-2017, 07:40 | #14 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | Searching Samsung modem... detected COM270 Reading phone info... OK Model: SM-G610F AP version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CP version: G610FDDU1APJ6 Product code: SM-G610FZKDKSA Phone SN: R58J42193BB Unique number: CAJ035C14C06F24 Reading IMEI... OK IMEI: 354772082292695 (SIGN: OK) Reading IMEI 2... OK IMEI 2: 354773082292693 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON315 HWID: 75 07 00 00 00 00 00 00 00 00 00 00 A7 80 99 2E Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:11) Freeze code: 50937047 NET lock: 61419264 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.6 downgrade for you https://drive.google.com/file/d/0B_W...dEWWNMSUk/view |
The Following 4 Users Say Thank You to JONONItelecom™ For This Useful Post: |
