01-11-2018, 17:34 | #1 (permalink) |
Insane Poster Join Date: Aug 2016
Member: 2611417 Status: Offline Thanks Meter: 9 | G892A FRP Fail Cant remove FRP via Bluetooth device because cant open chrome or any app Could someone share engboot Thanks сайты с картинками Any advice? I will donate |
02-15-2018, 17:38 | #5 (permalink) |
Freak Poster Join Date: Dec 2008 Location: SKN Caribbean Age: 41
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | I have G892A frp issue here and i already enable the usb adb options using the calculator. the problem is z3x doesn't have FRP reset Button is there any one can help me about this please.. thanks UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Info Selected model: SM-G892A Software version: 30.8 Searching Samsung modem... detected COM64 Reading phone info... OK Model: SM-G892A AP version: G892AUCS1AQJ2 CSC version: G892AATT1AQJ2 CP version: G892AUCS1AQJ2 Product code: ATT Phone SN: R38J708VV8L Unique number: 98899543514C4A4F32 Reading IMEI... OK IMEI: 357*********** Done with Samsung Tool PRO v.30.8 |
02-15-2018, 17:52 | #6 (permalink) | |
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | thanks anyway, done with other box Quote:
