12-17-2015, 09:27 | #4 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G900F Software version: 23.5 File analysis... OK Total file size: 0x95CD58C0 (2396 Mb) Searching USB Flash Interface... detected COM35 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:06:00) Done with Samsung Tool PRO v.23.5 |
12-17-2015, 13:16 | #8 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | not supported by Z3X at vthis moment but you can try this methode http://forum.gsmhosting.com/vbb/f777...azone-1990399/ |
12-17-2015, 14:03 | #10 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 23.5 Searching Samsung USB Flash Interface... detected COM35 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... not supported Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.23.5 |
The Following User Says Thank You to mahi20015 For This Useful Post: |
12-18-2015, 02:34 | #12 (permalink) | |
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
have u try this method http://forum.gsmhosting.com/vbb/f777...azone-1990399/ | |
01-04-2016, 15:36 | #14 (permalink) | |
Insane Poster Join Date: Aug 2006
Member: 330143 Status: Offline Thanks Meter: 4 | Quote:
whetre is this option in ver 23.9 | |
