06-22-2015, 23:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | G900p unlock fail Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900P Selected port: COM40 SAMSUNG Mobile USB Serial Port , Software version: 21.5 Reading phone info... Reading IMEI... OK IMEI: 990004437756632 Reading security... new type Bypassing... error Done with Samsung Tool PRO v.21.5 please help any tips |
06-23-2015, 00:17 | #2 (permalink) | |
Insane Poster Join Date: Dec 2013 Location: Santa Ana, CA
Member: 2082382 Status: Offline Thanks Meter: 18 | Quote:
The Following User Says Thank You to tamluu243 For This Useful Post: |
06-23-2015, 22:00 | #3 (permalink) | |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | Quote:
06-24-2015, 00:42 | #5 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Irvine, CA
Member: 2213954 Status: Offline Thanks Meter: 39 | If that doesn't work for you, because it works only with Kitkat and not lollipop, make sure to send 16 digit password: 2012112120131219 using either DFS or CDMA workshop before you try to unlock using Z3X. sometimes you have to send MSL but that's sometimes depending on the phone i guess. |
06-24-2015, 01:26 | #6 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
06-25-2015, 04:09 | #11 (permalink) |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | This is a compilation of threads that I used in order to SIM unlock a Sprint Galaxy S5 G900P that came with Lollipop 5.0. I have always used the SSU.apk from this incredible thread in order to unlock my sprint Galaxy S4, S5 and Note devices. However, whenever I install the apk and try to run it on 5.0, I get an error saying that the application (SSU) stopped working or something like that and it doesn't even work. Just to be clear, I didn't came up with this idea. This is just a compilation of different ideas that I found on XDA on different thread to accomplish this. Disclaimer: Do this at you own risk. I am not responsible for anything that happens to your device. I can only assure you this worked for me. Use this steps to Sim unlock you G900P from Sprint running Lollipop 5.0 1. Downgrade your ROM from Lollipop 5.0 (OA6 ) to Kitkat 4.4.2 (NE5) using this link . Yes you can do this!!! -Remember for this step you need Odin 2. Unlock you device by Installing and running SSU.apk using this thread At this point your device should be unlocked. If you want to go back to Lollipop OA6 proceed to step 3. 3. Download the Lollipop 5.0 ROM OA6 from here and flash it using Odin by following the same steps on point 1. That is all. I hope this helps you guys as much as it did to me. |
06-25-2015, 21:48 | #12 (permalink) | |
The Following User Says Thank You to F_X For This Useful Post: |
