08-11-2015, 12:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 161823 Status: Offline Thanks Meter: 71 | G900p unlock promble v 5.0 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900P Selected port: COM35 SAMSUNG Mobile USB Serial Port Software version: 22.0 Reading phone info... Reading IMEI... OK IMEI: 990004505637755 Reading security... new type Bypassing... error Done with Samsung Tool PRO v.22.0 |
08-11-2015, 16:29 | #2 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | Quote:
http://forum.gsmhosting.com/vbb/f453...e-z3x-1975609/ | |
08-11-2015, 22:04 | #3 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | 1. philz_touch_6.26.2-klte.tar.md5 2. SM-G900P_NI3_ROOTED_ODEXED.zip The trick here is to send SPC and security password so the phone can give access. I found out that DFS CDMA Tool is the best for that so I used it to send SPC and PWD and this is what happened: [ 7/21/2015 3:47:00 AM ] Operation: Unlock [ 7/21/2015 3:47:00 AM ] Selected model: SM-G900P [ 7/21/2015 3:47:00 AM ] Selected port: COM7 SAMSUNG Mobile USB Serial Port [ 7/21/2015 3:47:00 AM ] Software version: 21.8 [ 7/21/2015 3:47:00 AM ] [ 7/21/2015 3:47:00 AM ] Reading phone info... [ 7/21/2015 3:47:00 AM ] Reading IMEI... OK [ 7/21/2015 3:47:00 AM ] IMEI: 9900XXXXXXXXXXX [ 7/21/2015 3:47:00 AM ] Reading security... new type [ 7/21/2015 3:47:00 AM ] Bypassing... OK [ 7/21/2015 3:47:00 AM ] Unlocking... OK [ 7/21/2015 3:47:00 AM ] Reseting... OK [ 7/21/2015 3:47:00 AM ] Unlock done Again... I downgraded the phone and rooted it... The most important part is send SPC (unique) and Security PWD (2012112120131219) using DFS CDMA Tool before working with Z3X, once SPC and PWD are sent using DFS close DFS and you will be able to work on the phone using Z3X. Once again no domestic unlock... We need a way to enable all bands and also remove the domestic blocking... Right now if I could add |
08-12-2015, 08:34 | #4 (permalink) | |
Member: 161823 Status: Offline Thanks Meter: 71 | Quote:
bro my phone ver 5.0 downgrade promble FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G900P Software version: 22.0 File analysis... OK Total file size: 0x91631DD8 (2326 Mb) Searching USB Flash Interface... detected COM10 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... error timeout Done with Samsung Tool PRO v.22.0 | |
08-12-2015, 08:54 | #5 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
dont play with downgrade qualcomm!! You will have dead phones!! | |
The Following User Says Thank You to blang For This Useful Post: |
