06-06-2015, 05:37 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: near da border
Member: 861495 Status: Offline Thanks Meter: 52 | g900t need help imei null basband unknown after i load qcn ive been trying to fix it all day Operation: Unlock [ 6/6/2015 5:46:00 AM ] Selected model: SM-G900T [ 6/6/2015 5:46:00 AM ] Selected port: COM88 SAMSUNG Mobile USB Serial Port , [ 6/6/2015 5:46:00 AM ] Software version: 21.3 [ 6/6/2015 5:46:00 AM ] [ 6/6/2015 5:46:00 AM ] Reading phone info... [ 6/6/2015 5:46:00 AM ] Reading IMEI... OK [ 6/6/2015 5:46:00 AM ] IMEI: 351881069652855 [ 6/6/2015 5:46:00 AM ] Reading security... new type [ 6/6/2015 5:46:00 AM ] Bypassing... OK [ 6/6/2015 5:46:00 AM ] Unlocking... OK [ 6/6/2015 5:46:00 AM ] Reseting... OK [ 6/6/2015 5:46:00 AM ] Unlock done [ 6/6/2015 5:46:00 AM ] [ 6/6/2015 5:48:00 AM ] Operation: Write QCN [ 6/6/2015 5:48:00 AM ] Selected model: SM-G900T [ 6/6/2015 5:48:00 AM ] Selected port: COM88 SAMSUNG Mobile USB Serial Port , [ 6/6/2015 5:48:00 AM ] Software version: 21.3 [ 6/6/2015 5:48:00 AM ] [ 6/6/2015 5:48:00 AM ] Reading QCN file... OK [ 6/6/2015 5:48:00 AM ] Checking phone at COM88 [ 6/6/2015 5:48:00 AM ] Detected ID: 00000FF3 (MSM8974) [ 6/6/2015 5:48:00 AM ] SW Version: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-1.01647286.3416.1 [ 6/6/2015 5:48:00 AM ] Checking paths... OK [ 6/6/2015 5:48:00 AM ] Restoring EFS Backup... OK [ 6/6/2015 5:48:00 AM ] Restoring NV Items... error (3) [ 6/6/2015 5:48:00 AM ] [ 6/6/2015 5:49:00 AM ] Operation: Write QCN [ 6/6/2015 5:49:00 AM ] Selected model: SM-G900T [ 6/6/2015 5:49:00 AM ] Selected port: COM88 SAMSUNG Mobile USB Serial Port , [ 6/6/2015 5:49:00 AM ] Software version: 21.3 [ 6/6/2015 5:49:00 AM ] [ 6/6/2015 5:49:00 AM ] Reading QCN file... OK [ 6/6/2015 5:49:00 AM ] Checking phone at COM88 [ 6/6/2015 5:49:00 AM ] Detected ID: 00000FF3 (MSM8974) [ 6/6/2015 5:49:00 AM ] SW Version: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-1.01647286.3416.1 [ 6/6/2015 5:49:00 AM ] Checking paths... OK [ 6/6/2015 5:49:00 AM ] Restoring EFS Backup... OK [ 6/6/2015 5:49:00 AM ] Restoring NV Items... error (3) [ 6/6/2015 5:49:00 AM ] [ 6/6/2015 5:50:00 AM ] Operation: Read QCN [ 6/6/2015 5:50:00 AM ] Selected model: SM-G900T [ 6/6/2015 5:50:00 AM ] Selected port: COM88 SAMSUNG Mobile USB Serial Port , [ 6/6/2015 5:50:00 AM ] Software version: 21.3 [ 6/6/2015 5:50:00 AM ] [ 6/6/2015 5:50:00 AM ] Checking phone at COM88 [ 6/6/2015 5:50:00 AM ] Detected ID: 00000FF3 (MSM8974) [ 6/6/2015 5:50:00 AM ] SW Version: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-1.01647286.3416.1 [ 6/6/2015 5:50:00 AM ] Reading ESN... OK [ 6/6/2015 5:50:00 AM ] Backuping RFNV... OK [ 6/6/2015 5:50:00 AM ] Backuping Feature Mask... OK [ 6/6/2015 5:50:00 AM ] Backuping NV Item... OK [ 6/6/2015 5:51:00 AM ] Backuping NV Item SIM1... OK [ 6/6/2015 5:53:00 AM ] Backuping NV Item SIM2... OK [ 6/6/2015 5:54:00 AM ] Backuping Provisioning Item Files... OK [ 6/6/2015 5:54:00 AM ] Reading QCN done success [ 6/6/2015 5:54:00 AM ] [ 6/6/2015 5:57:00 AM ] Operation: Write QCN [ 6/6/2015 5:57:00 AM ] Selected model: SM-G900T [ 6/6/2015 5:57:00 AM ] Selected port: COM88 SAMSUNG Mobile USB Serial Port , [ 6/6/2015 5:57:00 AM ] Software version: 21.3 [ 6/6/2015 5:57:00 AM ] [ 6/6/2015 5:57:00 AM ] Reading QCN file... OK [ 6/6/2015 5:57:00 AM ] Checking phone at COM88 [ 6/6/2015 5:57:00 AM ] Detected ID: 00000FF3 (MSM8974) [ 6/6/2015 5:57:00 AM ] SW Version: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-1.01647286.3416.1 [ 6/6/2015 5:57:00 AM ] Checking paths... OK [ 6/6/2015 5:57:00 AM ] Restoring EFS Backup... OK [ 6/6/2015 5:58:00 AM ] Restoring NV Items... OK [ 6/6/2015 5:58:00 AM ] Restoring NV Item SIM1... OK [ 6/6/2015 5:58:00 AM ] Restoring Provisioning Item Files... OK [ 6/6/2015 5:59:00 AM ] Restore QCN done |
06-06-2015, 06:54 | #4 (permalink) | |
Junior Member Join Date: May 2014 Location: Los Angeles
Member: 2194977 Status: Offline Thanks Meter: 1 | Quote:
06-06-2015, 07:03 | #7 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | the fone was already unlocked but customer said he could only all the companies to work except one the one he wanted damn if i would known it was gonna be this uch trouble i wouldve just gave the fone back |
06-06-2015, 19:06 | #11 (permalink) |
Freak Poster Join Date: May 2014
Member: 2183509 Status: Offline Thanks Meter: 68 | Here you bruh! EFS Backup for G900T https://mega.nz/#!9hJkXIaZ!-utkhPUy1...4zDRY9uPFg6jT0 QCN for G900T https://mega.nz/#!MtIjFLKK!n7CO6a0Ep...0K52YhdmoXQcMI |
The Following User Says Thank You to noahark For This Useful Post: |
06-06-2015, 21:08 | #13 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | i think i got a break trew but not quite there can anybody help REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Fill values what you need to repair. 10. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Press 'Wipe EFS/NVM' button. Operation: Wipe EFS/NVM Selected model: SM-G900T Selected port: COM88 SAMSUNG Mobile USB Serial Port , Software version: 21.3 Waiting ADB device... OK Reading phone info... Model: SM-G900T Android version: 4.4.2 Product code: Phone version: PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH CSC country code: USA CSC sales code: TMB HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G900T Android version: 4.4.2 Product code: Not Active Phone version: G900TUVU1ANCH PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH CSC country code: USA CSC sales code: TMB HW version: G900T.00 Phone S/N: R38F7099H1Y Modem board: MSM8974PRO RF cal date: NONE IMEI: Checking Super user right... true Done with Samsung Tool PRO v.21.3 but before this i went to old samsung tool 19 and did wipe mr blang if u could please help |
06-06-2015, 21:15 | #14 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | Operation: Write CERT Selected model: SM-G900T Selected port: COM88 SAMSUNG Mobile USB Serial Port , Software version: 21.3 Checking certificate file... OK KEY ID: 0478 Waiting ADB device... OK Reading phone info... Model: SM-G900T Android version: 4.4.2 Product code: Not Active Phone version: G900TUVU1ANCH PDA version: G900TUVU1ANCH CSC version: G900TTMB1ANCH CSC country code: USA CSC sales code: TMB HW version: G900T.00 Phone S/N: R38F7099H1Y Modem board: MSM8974PRO RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.21.3 fixed there is defintely a bug in the new version and i also did a few "skip qvnvm checks " thx to everyone who helped i believed this solved will post back after sum tests |
06-06-2015, 22:00 | #15 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | The S5 lineup doesn't need a QCN afaik. Just wipe without backing up then write CERT. Win. Can't be much simpler. |
The Following User Says Thank You to ecs87 For This Useful Post: |
