02-25-2015, 02:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: USA
Member: 945085 Status: Offline Thanks Meter: 70 | g900v no service after... anyone have any other suggestions that i didnt try already? |
02-25-2015, 18:44 | #3 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | only thing that i did different in the beginning was to write a cert that starts with 35 and also matched it in dfs under meid. it wasnt working so i went back wiped and write cert that starts with 99 instead. dont think it matters but thought i'd mention it.. |
02-25-2015, 21:44 | #4 (permalink) |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | Why did you wipe the efs ? That's where you went wrong . And that's why there's no signal now nv items are damaged It's is how I fix the Verizon s5 1 root 2 write cert 3 match meid 4 switch to global mode and put in your apns 5 profit O forgot send 16 password and spc first before anything |
02-25-2015, 22:09 | #5 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | i did other 2 same day by wiping efs and they worked no problem.. ive also done many, many more in past same way no problem. nonetheless, do you have nv items file?? |
02-25-2015, 23:02 | #7 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | already sent those phones back out dont have any.. maybe in the next day or two ill receive some more. i do have good qcn backup file though i restored and still no service... shouldnt that work if i restored good qcn file? |
03-01-2015, 21:30 | #8 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | well today i had new verizon s5 never messed with before, i read qcn from it and tried to write in phone thats messed up. no luck.... i made sure everything else was good such as matched meid. anyone have any other suggestions as to what could be going on if after i write 100% good qcn phone still no service?? |
05-19-2015, 07:17 | #9 (permalink) |
Junior Member Join Date: Nov 2014 Location: Atlanta
Member: 2285262 Status: Offline Thanks Meter: 0 | Your assistance please Hello I'm having the same problem. Tried writing NV items from working phone. Still no luck! Here's what was done.... Wrote cert file Matched in CDMA No Signal Wrote NV from working phone exact same setup... Any assistance would be greatly appreciated. Thank you. |
05-19-2015, 18:14 | #10 (permalink) |
Member: 2285262 Status: Offline Thanks Meter: 0 | No Signal after repair Just an update as in starting over from square A everything worked out in regaining signal. 1) Upgrade from NCG to NK7 which repaired EFS (Kept Root) 2) write good NV (Octoplus used G900A) 3) write good cert (Octoplus used G900A) 4) Match cert in CDMA WS (all values) 5) Install sim and wait 5 - 10 mins for signal |
05-20-2015, 17:12 | #11 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | you have nk7? i thought after ncg is ne9? Quote:
05-22-2015, 04:00 | #13 (permalink) | |
Member: 1475064 Status: Offline Thanks Meter: 347 | you around bro?you around bro? Quote:
