11-26-2016, 06:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | g900V reactivation lock problem need help to remove reactivation lock from SM-G900V. i try combination file but getting error while writing system.img.... I try all other solutions..... by otg and by Side Sync not work for me....... i reset phone from menu by otg but still lock...... with Z3X no support for remove reactivation lock of this model (SM-G900V) and when i select other model ..... Code: Searching Samsung USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... not supported Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 i already search and found many threads but no one fix .......... tell me team if any solution ........ |
11-26-2016, 12:55 | #3 (permalink) |
Junior Member Join Date: Feb 2014 Location: USA
Member: 2124957 Status: Offline Thanks Meter: 1 | just try and downgrade to earlier fimware then use sidesync here try this one https://mega.nz/#!ccNzWbZK!DU9YDYy8q...mIZC1ejlGer2vc |
11-26-2016, 22:18 | #5 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | This model has a particular problem. I was able to add a different Samsung Account via combination file, but then after reflash standard firmware, cannot remove it altogether even though I know the password to the account. It will not let you untick the reactivation lock flag. |
12-11-2016, 07:55 | #9 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
there is 2 service. 1: by imei...... time need 24hr to 48. my done in 78hr 2: by remote ... this service is instant. both services are same prices. remote service i will test tomorrow INSHA ALLAH | |
The Following 2 Users Say Thank You to Hafiz ArslanAli For This Useful Post: |
