07-11-2015, 05:24 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 755471 Status: Offline Thanks Meter: 18 | G900W8 Problem after using z3x unlock can;t using winds any more? S5, note3 , note4 ,S6,S6 edge. |
11-30-2015, 21:54 | #3 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Quote:
However there was one phone very rare case that did not work on Wind, for that I had to change the CSC Code to GLW, for some strange reason after that phone did not work with LTE but it was working fine with wind. Also if you want LTE to work change the CSC code to BMC or TLS. Not sure if it makes a difference, but did solve my issue. Also dial *#2263# Option # 2 WCDMA, and then Option # 3 WCDMA 1700 <<< As wind uses AWS 1700 frequency might help you connect to Wind faster, but then if you are using 1700 frequency phone might not work in roaming as it uses Rogers as their roaming partners and Rogers does not use 1700 frequency well they bought MOBILICITY so not sure if they are sharing those towers with Wind as roaming. Anyways try above CSC *#CSC*IMEI NUMBER# or changing the band *#Band# Good Luck.. | |
