02-18-2016, 18:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | G903f successfully unlocked but can't permanently fix FRP error two days ago i have unlocked a 5.1.1 G903f, rooted with a file named "CF-Auto-Root-s5neolte-s5neoltexx-smg903f.tar.md5" one day after custumer bring it back with "custum binary blocked by FRP lock" error, i fixed it with reset FRP fonction, but today he has bring it back with the same error ! he said that after changing sim the probleme came again. so is this repair FRP fonction, a permanently or temporaly solution ? thanks Code: Searching Samsung USB Flash Interface... detected COM14 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.3 Last edited by .:bono:.; 02-18-2016 at 18:13. |
02-18-2016, 18:44 | #2 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Hello try To flash This will be problem solve I also face this same error in J200G customer came 3 times,then i flash it,after flash customer says mobile working Regards Rehan SHaikh |
02-18-2016, 18:48 | #3 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
thanks for replay, if i flash it, will the phone be locked again ? thanks | |
02-18-2016, 19:12 | #4 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
If your customer don't wait So there is temporarily bypass First go to settings then (about phone) then (softwareinfo) then tap 5 to 10 times on (build number) Then go back and there is a (developer settings) option on settings In developer settings (Enable OEM unlocking) There is no error like custom binary blocked by frp after that but if you reset your device then you want to repeat this process Br Shahzaib Jahangir | |
02-19-2016, 09:58 | #5 (permalink) | |
