11-05-2016, 17:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | g920a root BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G920A Software version: 27.0 Waiting ADB device... ok Reading phone info... Model: SAMSUNG-SM-G920A Android version: 6.0.1 Product code: SM2G920AZDAATT Phone version: G920AUCU3CPD6 PDA version: G920AUCU3CPD6 CSC version: G920AATT3CPD6 CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38G60FDS6D Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20150612 IMEI: Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.27.0 |
11-05-2016, 21:05 | #2 (permalink) |
No Life Poster Join Date: Nov 2007 Location: INDIA
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | Try this root mathod may be work http://www.androidrootz.com/2015/05/...xy-s6.html?m=1 Sent from my A79 using Tapatalk |
