05-09-2017, 15:45 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Poland, Poznan Age: 38
Member: 66993 Status: Offline Thanks Meter: 12 | G920f after upgrade to 7.0 out of network Samsung G920F after upgraded to android 7.0 can't call anymore. Still info: Out of service. imei is ok. Any idea? Thx. |
05-10-2017, 14:36 | #4 (permalink) |
Member: 66993 Status: Offline Thanks Meter: 12 | Waiting ADB device... Ok Reading phone info... Model: SM-G920F Android version: 7.0 Product code: Phone version: G920FXXU5EQCD PDA version: G920FXXU5EQD7 CSC version: G920FXEO5EQD1 CSC country code: Poland CSC sales code: XEO HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Initialization zTool... Ok Running zTool, please wait... Ok Reading modem... Ok Patching modem... Ok Writing modem... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.28.1 But still the same, can't call. |
05-11-2017, 06:52 | #5 (permalink) | |
Junior Member Join Date: May 2017
Member: 2713479 Status: Offline Thanks Meter: 9 | Quote:
Have you tried changing the modem? In odin just flash the CP file from other country, then patch again. Good luck! | |
05-11-2017, 12:03 | #7 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | @haller Downgrade to 6.0.1 and try calling if it doesn't work make cert and network repair, if it works and if you still want thr 7.0 update then flash only the ap(system.img). Good luck |
05-11-2017, 12:04 | #8 (permalink) |
Member: 2583091 Status: Offline Thanks Meter: 413 | @haller Downgrade to 6.0.1 and try calling if it doesn't work make cert and network repair, if it works Good!.and if you still want thr 7.0 update then flash only the ap(system.img) to not to mess up the modem. Good luck |
05-11-2017, 15:40 | #10 (permalink) |
Member: 66993 Status: Offline Thanks Meter: 12 | I tried one file, but error in odin. <ID:0/005> Odin engine v(ID:3.1203).. <ID:0/005> File analysis.. <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Get PIT for mapping.. <ID:0/005> Firmware update start.. <ID:0/005> SingleDownload. <ID:0/005> boot.img <ID:0/005> cache.img <ID:0/005> cm.bin <ID:0/005> FAIL! <ID:0/005> <ID:0/005> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) Any idea? |
05-11-2017, 16:34 | #11 (permalink) |
Member: 2583091 Status: Offline Thanks Meter: 413 | @haller You should be flashing with z3x instead of odin because on z3x you can specifically select what to flash like boot or recovery or system. so launch samsung tool pro then on the flash tab select ap then if you have 4 file firmware select ap from wherever it is located then on the right there are three dots, select the dots and untick all of them except system.img then flash. It doesn't matter whether you have four or one file firmware, if you have one select the file on ap and untick all except system.img. Hope this helps! |
05-12-2017, 10:16 | #12 (permalink) | |
Member: 66993 Status: Offline Thanks Meter: 12 | Quote:
I'm trying to downgrade only system.img, but after flash system.img, phone hang on first logo. Tried repair drk, but not helped. Last edited by haller; 05-12-2017 at 10:22. | |
