-   Z3X-Team Products (http://forum.gsmhosting.com/vbb/f453/)
-   -   G920F restart in Recoverry after flash (http://forum.gsmhosting.com/vbb/f453/g920f-restart-recoverry-after-flash-2419327/)
gilica_gsm 06-12-2018 17:03
1 Attachment(s)
hy
after flash G920FXXU6ERC1 phone in:
Error
Device does not have DRK, please install DRK first.
Press any buton
and Recovery mode
try to repait DRK but no luck:
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM11 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.32.7
phone restart in Recovery mode, no power on
please help to alive this phone
thx
voltran2008 06-12-2018 17:56
Try rooting your phone, it will fix dm-verification error...
gilica_gsm 06-12-2018 19:56
thx but how install supersu?, phone no have card slot and pc see phone as modem only
souma_k 06-12-2018 20:35
Custom recovery bro or patched boot using magisk it will bootup
IF THIS POST WAS HELPFUL PRESS [emoji173] BUTTON [emoji6]
voltran2008 06-12-2018 21:35
After installing TWRP
twrp-3.2.1-0-zeroflte.img.tar
with Odin Odin3_v3.13.1.zip (Don't forget to un-tick "Auto Reboot" in Options tab)...
Install Minimal ADB and Fastboot minimal_adb_fastboot_v1.4.3_setup.exe
Download and copy SuperSU-v2.82-201705271822.zip
or Magisk Magisk-v16.0.zip to Minimal ADB and Fastboot installed directory
(Default is for 64 bit Windows "C:\Program Files (x86)\Minimal ADB and Fastboot"
and for Windows 32 bit default is C:\Program Files\Minimal ADB and Fastboot)
Reboot to recovery wait 10-20 seconds.. and Open Minimal ADB and Fastboot...
type "adb devices" if you see a device then for SuperSu type: "adb push SuperSU-v2.82-201705271822.zip /sdcard"
and for Magisk type "adb push Magisk-v16.0.zip /sdcard"
Afterwards at TRWP Swipe and tap "Install" and install preferred root SuperSu or Magisk...
If you type "adb devices" and you don't see the device, at TWRP tap "Mount" and Enable/Disable MTP and you will see device listed...
gilica_gsm 06-13-2018 11:01
thx for all reply
done all above but phone stock on logo
tray Repair DRK but phone no enter ADB mode, see: recovery is not seandroid enforcing" and restart
Phone not found
nessyb 06-14-2018 20:57
Flash twrp and format data in recovery.. After that use sideload to flash magisk or su.. You can try to mount phone via recovery after format..this is a temporary fix for drk.. After boot try to repair drk via usb or uart for permanent fix
gilica_gsm 06-15-2018 08:39
thx to all
after wipe data and wait 20 minutes, phone start on and work fine
thx
Page generated in 0.23935 seconds with 5 queries
