Old 06-12-2018, 18:03   #1 (permalink)
Member: 85467
Thanks Meter: 70
G920F restart in Recoverry after flash
hy
after flash G920FXXU6ERC1 phone in:
Error
Device does not have DRK, please install DRK first.
Press any buton
and Recovery mode
try to repait DRK but no luck:
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM11 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.32.7
phone restart in Recovery mode, no power on
please help to alive this phone
thx
Old 06-12-2018, 18:56   #2 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,041
Try rooting your phone, it will fix dm-verification error...
The Following User Says Thank You to voltran2008 For This Useful Post:
Old 06-12-2018, 20:56   #3 (permalink)
Member: 85467
Thanks Meter: 70
thx but how install supersu?, phone no have card slot and pc see phone as modem only
Old 06-12-2018, 21:35   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,098
Custom recovery bro or patched boot using magisk it will bootup
IF THIS POST WAS HELPFUL PRESS BUTTON
Old 06-12-2018, 22:35   #5 (permalink)
Member: 861795
Thanks Meter: 1,041
After installing TWRP
twrp-3.2.1-0-zeroflte.img.tar
with Odin Odin3_v3.13.1.zip (Don't forget to un-tick "Auto Reboot" in Options tab)...
Install Minimal ADB and Fastboot minimal_adb_fastboot_v1.4.3_setup.exe
Download and copy SuperSU-v2.82-201705271822.zip
or Magisk Magisk-v16.0.zip to Minimal ADB and Fastboot installed directory
(Default is for 64 bit Windows "C:\Program Files (x86)\Minimal ADB and Fastboot"
and for Windows 32 bit default is C:\Program Files\Minimal ADB and Fastboot)
Reboot to recovery wait 10-20 seconds.. and Open Minimal ADB and Fastboot...
type "adb devices" if you see a device then for SuperSu type: "adb push SuperSU-v2.82-201705271822.zip /sdcard"
and for Magisk type "adb push Magisk-v16.0.zip /sdcard"
Afterwards at TRWP Swipe and tap "Install" and install preferred root SuperSu or Magisk...
If you type "adb devices" and you don't see the device, at TWRP tap "Mount" and Enable/Disable MTP and you will see device listed...
Old 06-13-2018, 12:01   #6 (permalink)
Member: 85467
Thanks Meter: 70
thx for all reply
done all above but phone stock on logo
tray Repair DRK but phone no enter ADB mode, see: recovery is not seandroid enforcing" and restart
Phone not found
Old 06-14-2018, 21:57   #7 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 436
Flash twrp and format data in recovery.. After that use sideload to flash magisk or su.. You can try to mount phone via recovery after format..this is a temporary fix for drk.. After boot try to repair drk via usb or uart for permanent fix
Old 06-15-2018, 09:39   #8 (permalink)
Member: 85467
Thanks Meter: 70
thx to all
after wipe data and wait 20 minutes, phone start on and work fine
thx
Page generated in 0.28066 seconds with 8 queries
